cluster problems
Old Jan 11, 2009 | 04:47 PM
hondakook's Avatar
Default cluster problems
i just finished my swap in my car and my cluster isnt working well the tempature gauge and gas gauge are but my odomoter,speedometer or R.P.M isnt working its a si cluster in a 96-98
Old Jan 11, 2009 | 06:17 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: cluster problems
Make sure the plugs in the back of the cluster are snuggly connected. That's my first look.
Old Jan 12, 2009 | 01:23 PM
hondakook's Avatar
those plugs are fine any other suggestions?
bump
Old Jan 12, 2009 | 04:39 PM
hondakook's Avatar
bump bump someone help it sucks driving a r swap with no rpm or speedometer
Old Jan 12, 2009 | 07:49 PM
hondakook's Avatar
**** honda-tech someone help bump
Old Jan 13, 2009 | 11:01 AM
aj_EGcivic's Avatar
bumppp
Old Jan 13, 2009 | 12:19 PM
Tate in action's Avatar
make sure you plugged your vss in
Old Jan 14, 2009 | 07:00 AM
hondakook's Avatar
vss is in bump
Old Jan 14, 2009 | 09:54 AM
court's Avatar
25 Year Member
there is a solid blue wire on your distributor plug packdo a volt check on that while the car is one. repport back with your findings
Old Jan 16, 2009 | 06:09 PM
hondakook's Avatar
bump
Old Jan 16, 2009 | 06:16 PM
highcompb18c's Avatar
did the cluster work before the swap or did you swap the cluster out during the swap?
Old Jan 16, 2009 | 07:41 PM
hondakook's Avatar
i swapped out the cluster during the swap but the si cluster worked fine in my other car idk what it is im using a 99 si engine harness someone told me i might have to use the orginal harness out of the 96-98 civic bump
Old Jan 17, 2009 | 12:39 PM
hondakook's Avatar
bump
Old Jan 20, 2009 | 04:52 PM
swap out the cluster to a car w/ a good known harness to see again if it works. if it does u have a wiring issue
Old Jan 20, 2009 | 06:30 PM
green99civic's Avatar
most of them are plug and play keep messin around with them until you got then on right u might have gotten a defective cluster just may not work period man
Old Jan 24, 2009 | 12:51 AM
hondakook's Avatar
yea but my cluster worked fine in my other car so i dont think its the cluster does anyone have a b-series motor in a 96-98 anf if so do you use the 96-98 harness or something different
Old Jan 24, 2009 | 09:14 AM
RACE NOT RICE's Avatar
Sounds like a VSS prob, or your not getting the RPM signal from your dizzy.
Old Jan 27, 2009 | 08:08 PM
hondakook's Avatar
bump i found a wire hanging out of my harness its blue and white i just dont know where to plug it into any input?
Old Jan 28, 2009 | 12:15 PM
hondakook's Avatar
bump bump
latinman07
Northeast (Sales)
May 3, 2013 04:25 PM
rrd5011
Dec 16, 2011 05:30 AM
love_ek9's
Southeast (Sales)
13
Dec 5, 2010 12:16 AM
maxwellmercer
Oct 3, 2010 06:36 PM
type-r-eg
Nov 19, 2009 06:38 AM
