B series into 1989 Integra??
I am trying to see if I can put a B series motor into a 1989 Integra. Would the mounts work? What exactly would I need to do this swap? Axles, ECU, Etc. Any links would help.
you can put a bseries in it, you would need the coresponding computer for the engine, axles, trans, complete wire haress, any parts the engine your putting in dosn have, if its not off a site like hmotors, like if you buy it for someone id suggest a new timing belt, water pump, timing belt tensioner, tune up before u put the engine in
check all the gaskets too, like the valve cover, spark plug tubes, oil pan, i mean u can do it in while the engines in, but it just makes it easier especially the timing belt
also id pick up a haynes or chiltons manual for the car, and itll tell u exactly how to take the engine out and re install
if your gonna be doing performance stuff to it, id probably get a chipped ecu with like hondata or somthing
Im concerned more with how I will bolt up the motor. Do I need the hasport kit or is there a way to use a variety of mounts off of other cars to make this work. Also, do I need a b series tranny or is the one on there going to work.
Ok so I got the motor mount kit ordered from Hasport. I already have a 96 LS motor and a 93 LS transmission. What axles do I need? What rear L bracket do I need?
I THINK 90-93 integra axles, but don't quote me. Try at http://www.g1teg.org the only place you should need to go, I would think.
Got an L bracket to work....now I need to know what axles to use? Also does anyone know what that other sensor on the exhaust cam side is. On the old motor is has a sensor on the exhaust side right next to the distributor. I wanna know what that is.
Your old motor was a D16a1 correct? The sensor I believe you are talking about is the cam positions sensor or called the CPK...In the new Honda motors the sensor is inside of the distributor...HTH
TouringAccord
Feb 12, 2024 09:02 PM
92lxsleeper
May 11, 2012 05:10 AM
usdmEHboy
Jan 31, 2007 09:02 PM
