B series timing belt.
im planning to tackle the timing belt by my self. DOes anyone know of online instuctions or a help guide..
or any tips of some sort.
anything would be appreciated
thanks!!! Erik
thanks!!! Erik
Former Moderator
Re: B series timing belt. (emueller1)
I'm sure there has to be a walk through somewhere on this site - try the FAQ topic that is stickied in this very forum.
As far as parts goes it's debatable, but IMO the following need to be done all at the same time:
Timing belt
Water pump
Drivebelts
Cam seals
Crank seal
Coolant (no choice really if doing waterpump)
Valvecover gasket
Spark plug tube seals (fit inside valve cover)
*Top washers/grommets for valvecover* - optional - replace if yours are squished out
*Timing belt tensioner* - Spin to feel for graininess, but honestly why take the chance and not do it?
Timing belt
Water pump
Drivebelts
Cam seals
Crank seal
Valvecover gasket
Here's excerpts from the factory service manuals. Start with the page in the link and on the left side or at the top you can forward to the next pages with more pics and descriptions...
http://redpepperracing.com/tec....html
The site has service manuals for many honda/acuras so if the GSR motor isn't what you have you can search around, but the procedure is pretty much the same anyways.
Former Moderator
Re: (emueller1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emueller1 »</TD></TR><TR><TD CLASS="quote">oh geez im a newb, its a jdm b16</TD></TR></TABLE>
When ordering parts ask for a 1995 Honda Del Sol VTEC model - the one that had a B16A3 engine in it.
I stongly suggest going OE Honda for these parts.
Check out http://www.hondaautomotiveparts.com for good prices on the genuine parts. If you're having trouble finding each individual part on their exploded diagrams simply call them and I'm sure someone can help you order the list I posted.
Re: (B18C5-EH2)
hmmmm
i have a obd1 ecu conversion or what ever.. where would the plug in so i can read what my cheak engine light is bringing up...
i was gong to order a toda racing timing belt.. s toda a good brand?
Sure a Toda belt is great... high-priced and not necessary, but a nice part. If you have a stock or near stock engine a factory belt will last a very long time.
Former Moderator
Re: (emueller1)
Toda T-Belt = waste of money
Like klugemonster stated it's a good product, but completely unnecessary.
You can go that website, or a local Honda dealership and order everything at one time rather than grab a belt here, other parts elsewhere, etc. etc.
Re: (B18C5-EH2)
where abouts would be the plug in for egine lights be? if i have a b16a3 swapped civic. it is a 0bd1 conversion on it too. its a 2000 civic dx hatch
On the harness right by the ecu plugs you will see a little 2 pin connector with a rubber cap on it, that is the service jumper connector. Use a peice of wire or a paper clip to bridge the 2 terminals, turn the key to the first position and count if the CEL light flashes. Long dashes mean 10, short ones mean 1. So if it flashes 2 long and 5 short that would be 25. If there are multiple codes they will flash from lowest to highest number and keep repeating themselves with a pause between them.
