charcoal canister questions???
Old Jan 11, 2009 | 04:43 PM
jdmdc2boi12's Avatar
Default charcoal canister questions???
hey guys, i was working on my car today and i accidently broke the tip wher the tube goes all the way to intake manifold..now im planning to get a new one... Is this something i should worry about? can u guys help me with these? thank you in advance.. btw this is not the actual pics.. will delete upon owner requestt...this is the black cannister that i circled...
Old Jan 11, 2009 | 04:53 PM
Jimmy's Avatar
Global Moderator
Default Re: Can u guys help me
That's your ''charcoal canister'' .. What year is your car? I don't think on an OBD-1 car those are important.. to be honest.. i took mine off and threw it in the trash can.. I haven't had any problems without it.
Old Jan 11, 2009 | 05:25 PM
mine is 94 ls integra
Old Jan 11, 2009 | 05:33 PM
DC_Legacy's Avatar
Yeah, mines there but it isnt hooked up and working perfectly fine without.
Old Jan 11, 2009 | 05:53 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
you don't need it to run the car. But since your in calie. And we have the most pia cops and smog rules. You are going to have to replace it so you can pass smog or don't have cops hassle you if you get your hood popped. You might be able to install a new brass tip on it. Pic of the real damage. There is also a member in the socal f/s thread selling one too if you want to replace the whole thing
Old Jan 12, 2009 | 01:19 AM
vietnamezerice's Avatar
hopefully you can find someone NOT from california that removed theirs
Old Jan 12, 2009 | 09:15 AM
kragen doestn seem to have that canister or any local stores around my area.. can anyone give me the part number or any help would be appreciated...
ill post some pics soon... just waiting for the wifey to get home cuz she has the camera
Old Jan 12, 2009 | 09:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I don't think you want to try to buy a brand new one, they cost over $150
For those that don't have one or don't have it hooked up, do you smell gasoline vapors around your engine bay? The charcoal canister is there to route gasoline vapors from the fuel tank into the intake manifold. I don't know about ya'll, but I don't want my car smelling like gas around the outside. That's just embarrassin'
Old Jan 12, 2009 | 12:05 PM
StokelesS_g2's Avatar
I just ran the fuel vapor return hose to the TB instead of going threw the charcoal canister.
Never smelt any fuel.
Old Jan 12, 2009 | 12:19 PM
mouab18c1's Avatar
you dont need it...i took mine off my 97 gsr. just remember to plug off your vacuum hoses that connects to it...
Old Jan 12, 2009 | 05:08 PM
i dont smell anything, not even a bit..
Old Jan 12, 2009 | 05:10 PM
im sure i would need to have it for me to pass the smog here in california.. can someone clarify that for me? do we californians need the canister to pass SMOG?
Old Jan 12, 2009 | 05:33 PM
I'm sure you do
Old Jan 12, 2009 | 05:39 PM
racebum's Avatar
i did this to another car and you can smell vapor on hot days. on obd1 it's no big deal code wise. on obd2 the check valve stays closed when the engine is cold. you probably could take it straight to the TB from the check valve since the JDM engines already do this and have a port on the TB for it.
Old Jan 12, 2009 | 05:49 PM
Jimmy's Avatar
Global Moderator
Me neither.
Old Jan 12, 2009 | 06:56 PM
Default Re: charcoal canister questions???
hmm... makes me want to remove the one out of my DB now :D
Old Mar 10, 2009 | 02:48 PM
rb240z71's Avatar
Yup you need it in CA, there's a new test call EVAP along with the smog test for OBD1 cars, it tests if there's a leak from the fuel tank to the charcoal canister
Old Jun 30, 2011 | 01:02 PM
97rhdintegra's Avatar
i have a problem with mine does a 95 charcoal canister pass smog on a 97 Ls?
DOOM1
Mar 16, 2016 05:49 PM
W.O.P.
Aug 24, 2004 03:11 PM
AR Fab
Jul 24, 2004 11:00 AM
Hairy Gorilla
Dec 15, 2003 01:43 PM
RSVTECDC4
Jun 21, 2003 01:02 AM
