CEL P1259 - 96 Integra GSR: How to fix?
Old Jan 11, 2009 | 04:24 PM
bluebomber's Avatar
Information Leafblower
Default CEL P1259 - 96 Integra GSR: How to fix?
Hi, I've got a 5-speed 1996 Acura Integra GSR. It's got 177k on it. Last week, my CEL came on.
I had the oil changed today, and the light is still on. The tech ran the diagnostic tool and it came back as P1259 VTEC System Malfunction. The oil isn't low (was changed today), I don't have a VTEC controller, and the only engine mod is a AEM CAI that I put on over 2000 miles ago.
Does anyone know how I can fix it?
Old Jan 11, 2009 | 04:58 PM
HONDAPARTSMANMIKE's Avatar
Default Re: CEL P1259 - 96 Integra GSR: How to fix?
did you clear the light after the oil change?
its possible you may need the vtec solenoid assembly.
Old Jan 11, 2009 | 05:44 PM
bluebomber's Avatar
The light wasn't cleared after the oil change.
Old Jan 11, 2009 | 08:05 PM
clear the light with a scan tool or by disconnecting the battery or you can remove the under hood fuse for the radio i believe and that should clear the light. and you should have vtec again. was the oil low before the oil change?
Old Jan 11, 2009 | 08:16 PM
bluebomber's Avatar
I think it was low; I drove about 4,000 miles before I changed the oil.
Old Feb 13, 2009 | 05:50 PM
bluebomber's Avatar
In case anyone was wondering, I fixed this problem. It was caused by my GSR burning a little bit of oil, and I didn't replace it, so the CEL came on when the fluid was low. Changing the oil and resetting the ECU solved the problem, and it hasn't come back since.
Londo2557
Nov 28, 2016 07:27 AM
Pr-Type-R
Apr 20, 2008 05:09 PM
Cashflo
Sep 26, 2006 01:47 PM
lilxvtecxpwr
Sep 4, 2003 10:51 PM
jond
Mar 30, 2003 12:09 PM
