Is 17 volts coming from the alternator bad?
Old Jan 11, 2009 | 02:18 PM
rodan's Avatar
Default Is 17 volts coming from the alternator bad?
My alternator is putting 17v+ to my battery when it's running The battery sit at 14v+ when it is off. I'm not sure but I think thats a bad thing when everything in my car is supposed to see 12v. I'm afraid to drive the damn thing in fear the Optima Yellow Top will explode or something electrical will get damage. Any Ideas is this a voltage regulator issue?
Old Jan 11, 2009 | 02:21 PM
quicksilver1689's Avatar
i ♥ snails
Default Re: Is 17 volts coming from the alternator bad?
thats pretty high man, 13.5-14.5 is considered the normal output, check the v-reg
Old Jan 11, 2009 | 02:55 PM
srmofo's Avatar
yup thats bad, and it will over charge your battery which can indeed cause your battery to blow, in all likely hood, it will just crack and spill the acid (or in your case acid gel) all over the place....eitherway its not good dont drive it till you get it fixed
Old Jan 12, 2009 | 02:37 PM
rodan's Avatar
All is good. It was just my cheap Harbor Freight DMM. Bought a new one from Sears and it read the voltage within the limits. Thanks for the replys.
Old Jan 12, 2009 | 04:26 PM
i ♥ snails
what a pos dmm
Old Jan 12, 2009 | 04:47 PM
HamiltonRex's Avatar
i wouldn't even trust the sears one.
Old Jan 12, 2009 | 06:38 PM
srmofo's Avatar
Originally Posted by quicksilver1689
what a pos dmm
for $2.99, what do you expect
FRKWOO
14
Feb 14, 2010 09:54 AM
raidacaipo
10
Jul 29, 2008 01:13 AM
Riceburner247
Oct 12, 2005 07:04 PM
mt23vtecbb2
Nov 27, 2003 08:57 PM
bluegoo
Nov 17, 2002 09:39 PM
