1998 Civic Wiper Problem
Hey, I have read a few threads about the notorious wiper motor issue, but that doesnt seem to apply to my car. I changed the motor today and it didnt fix anything. my problem isnt really the 'parking' that i read about in the bulletin, my intermittent, and low dont work, only high works.. i can hear a click in the dash on the intermittent setting as if it is working, but the wiper wont budge.. any ideas?
It could very well be the switch.
When purchasing a wiper switch for a 6G Civic, remember there are two types. There is the normal type and then there is the type for DX hatchbacks, which have controls for the rear wiper.
How about a DX coupe?.. my local wrecking yard has a 99 dx coupe, it might fit.. they are like $90 new, i need to get by as cheap as i can for now.. Thanks
That is definitely not the motor. If you have settings on the switch that don't work but the high works then it's the switch. If the motor was bad you most likely wouldn't have anything working or working intermittently. A DX coupe will work for you. I'd highly recommend purchasing a new one from the local auto parts store though. Used electronic items are kind of a no-no from the junkyard.
Used should work just fine. I've used used headlight and wiper switches on cars here and have never had a problem.
Replace the motor and it fixes it. At least it does if the issue is that park switch in the motor.
My car actually had this issue. Replaced the motor and I've had no problem since.
That's talking about a parking problem though, he's saying the settings just plain don't work. Generally if the settings don't work, it's the switch and if it parks incorrectly then it's the motor, from what I've seen anyway with working on cars.
I really like how the Civic wipers work though. If you have the switch off and hit the mist setting you can park the wipers basically where you want. Not sure if it's supposed to work like that, but during the winter it makes it so you can park the wipers directly over the defrost vent on the windshield and thaw the ice off them.
You wanna fight NOFX? Time to throw down!
Out of the issues I've ever had, it was the switch, not the motor. If you're talking about RX-7's, switch was ALWAYS the problem. I haven't had a motor fail on me yet.
I know it sounds like it'd only be a switch issue, but it's not always that way.
Hi there. I have the same problem as you described it (including the clicking sound coming from the wiper motor when the switch is set on the "intermittent wiper" setting). When you swapped the wiper motor, did the new motor make the same sound in the intermitten wiper setting? Also, have you tried repolacing the switch itsel as suggested by The_Honda_Guy? Just wondering what progress you made so far on the issue. Thanks!
Nothing like posting years later, but it may help someone.
I've had a similar problem where low and high worked fine but no intermittent (98 Civic DX)
I finally traced it down to a control module mounted on the back of the fuse box. (ECM Integrated Control Unit TRX 38600-SO1-A1).
It's a 10 minute fix. I picked one up at the pick and pull yard for $3.
It's a black box that will pop off the back of the fuse box. You'll have to unplug one set of wires either before or after you pop off the black box.
Hope that helps someone!
CivicDynamo94
Sep 13, 2011 04:56 PM
racing_reject_001
Feb 18, 2011 12:40 PM
jxhxb
Dec 22, 2007 06:02 PM
