hood latch problem
Old Jan 11, 2009 | 09:09 AM
efjones9's Avatar
Default hood latch problem
i went to open my hood 2day and the release lever was easy to pull. so im guessing sumthan is broken? my hood didnt open at all. how would i get the hood open? i went to pick and pull and got another cable and lever, but how do i pop the hood?
thanx in advance
Old Jan 11, 2009 | 09:58 AM
Ldo's Avatar
Ldo
Default Re: hood latch problem
Jack the car up, look up from underneath and see if you can reach that lever.
Old Jan 11, 2009 | 10:10 AM
JustAnotherRex's Avatar
If it is just stretched out, you could try having a friend push down on the hood while you pull the cable and you may get it to pop up. When my latch was maladjusted for a C/F hood I had, that'd work.
Old Jan 11, 2009 | 10:36 AM
efjones9's Avatar
ya i think its the cable..ill try that
Old Jan 11, 2009 | 11:01 AM
Bill_Ee9's Avatar
had the same problem a while ago,
i thought that it was the cable but you just need to adjust the spring preload.
Old Jan 11, 2009 | 01:04 PM
honda.lioness's Avatar
Make sure the groove in the sheathing on the cable (in the driver's footwell) fits into the groove in the hood release lever bracket. Then use pliers to pull hard on the cable end. You may have to use a jack to pull it hard enough. Then thoroughly clean (w/PB Blaster, say) and lube (with white lithium grease or silicone spray lube) the latch at the hood. Test without fully closing the hood. If it is persnickety, replace the cable per http://honda.lioness.googlepages.com/hoodreleasecable.
Online, a new OEM cable runs $35 + ridiculous shipping costs. It will be more at your local dealer. My junkyard cable (which I tested before removing and buying) works great for $6.
This is a very common problem.
DAlexsanderC
Feb 19, 2011 06:04 PM
90si-rex
11
Dec 4, 2008 07:05 PM
boostedhks
Jul 24, 2008 07:45 PM
EJ1Dream
Jan 3, 2007 07:04 PM
naterpatater77
Feb 29, 2004 05:32 PM
