help d16y8 swap
Old Jan 11, 2009 | 03:37 AM
ek_civic96's Avatar
Default help d16y8 swap
Hi, i'm sorry for being such a noob, but i'm in a difficult situation and i need your help. I recently swap my 96 civic hatchback cx old d16y7 into a d16y8 from a 96-98 coupe ex with the ex wire harness and bought a obd2a to obd1 harness conv. and I'm using a stock p28 ecu. Isn't it suppose to work correctly? However, when i start the car it seems to be sucking a lot of juice from battery and the light dim on and off, check engine light is on, and it idle a bit. What could it possibly be wrong? I'll appreciate if you experts help me out. Thank you in advance....
Old Jan 11, 2009 | 04:35 AM
Xscort's Avatar
Default Re: help d16y8 swap
Did you hook up that alternator ground cable to the underhood fuse box?? Should be two slots with two grounds going to it.
Old Jan 11, 2009 | 05:37 AM
sql_civic's Avatar
What DTC is the ECU reporting?
Old Jan 11, 2009 | 12:43 PM
ek_civic96's Avatar
yes i did...Thanks for the help. Anyways it's working now correctly now...
king_pin
Mar 4, 2009 12:09 PM
king_pin
10
Feb 8, 2009 10:01 AM
icucnme
Feb 11, 2004 12:32 PM
Ransom
Aug 29, 2002 07:11 PM
