Engine Diaper for Sports Compact
Old Jan 10, 2009 | 11:43 PM
inboost_sa's Avatar
Default Engine Diaper for Sports Compact
Hi Guys
The Motorsport guys in South Africa Whant us to all use
Engine Diaper for 2009
just would like to know do you guys use Engine Diaper
and how does it affect heat transfer ect
i have seen some catch trays under motors
but never seen any Engine Diaper
can some one help ???
Old Jan 11, 2009 | 12:33 AM
toyotaturbo's Avatar
Default Re: Engine Diaper for Sports Compact
Hello. As long as it doesn't have to be SFI Certified, check out this link:
http://store.summitracing.com/egnsea...174&D=%2D87174
Check out Part number RCI-7811A. Hope that was helpful!!
Old Jan 11, 2009 | 10:22 AM
Garcia-Racing's Avatar
Deist safety makes one that works well for hondas
Old Jan 11, 2009 | 12:11 PM
inboost_sa's Avatar
my question is are you guys useing
engine diapers as i could not see them
Old Jan 11, 2009 | 12:15 PM
SPOOLINmatt's Avatar
if you have a pan, you just simply lay the diaper material down in the pan, nothing is sacrificed.
Old Jan 11, 2009 | 12:40 PM
ExospeedAMcrx's Avatar
The problem with making an engien diaper is that it has to be Specific to the engine AND even with that, alot of racers have different setups that can cause clearance with the mounting points and shape of the blanket.
The Engine blanket was never really Enforced strictly here in the US. Its hard to make something that can fit universally with every engine, turbo manifold, downpipe configuration out there. The best bet in my opinion is to get one custom made to your setup. We used Deist Safety all the time since they do custom stuff all the time.
You can send a template made out of cardboard or cloth or something that they can see the shape how you want it made.
Old Jan 11, 2009 | 05:56 PM
DaveF's Avatar
i belive it was "NFJohn" that said it before, Taylor Engineering has a b series diaper.
we havent used a diaper in the past, but the catch tray's we run seem to work rather well, even more so with the "NHRA spec" 2" lips on them. the absorbant material in the bottom of the pan does an exellent job.
Old Jan 11, 2009 | 07:58 PM
inboost_sa's Avatar
Thanks guys
k2GM
Engine Management and Tuning
Nov 9, 2010 04:12 PM
matttegra
Jun 1, 2009 06:34 PM
lilcasino
Oct 2, 2002 06:58 PM
GettaluvR
Jun 27, 2002 11:14 AM
