Ignition Switch ?- PLZ HELP
Old Jan 10, 2009 | 03:35 PM
SinsEvil666's Avatar
Default Ignition Switch ?- PLZ HELP
im trying to figure out where do the ignition switch plugs go under the dash....(im a total noob) well, i have a 97 Hatch....i went to junkyard and picked up a 91 ignition switch...it fits in the steering column for the 97, but is the wiring harness compatible with the 97 underdash/fuse box wiring harness? is it the same for all civics when it comes down to the ignition switch?
Thank you.
Old Jan 10, 2009 | 05:14 PM
Default Re: Ignition Switch ?- PLZ HELP
anyone?
Old Jan 10, 2009 | 05:17 PM
HONDAPARTSMANMIKE's Avatar
are the plugs the same and are the wire colors the same???
Old Jan 10, 2009 | 05:30 PM
i found a connector clipped on the side of the fusebox (Brown-from dash harness) One of the ignition switch plug did fit there, the wires look the same as for thickness...dont really remember colors it was kind of dark... as for the other ignition switch plug (smaller one), there is an open connector on the fuse box where the plug fits and clips in perfectly...but im unsure if it goes there as there is no wires i can see to compare from the fuse box, Anyone know?
Also, for the interior dash harness, anyone have a pic to show me where the plugs go?
HONDAPARTSMANMIKE, the plugs coming from the ignition switch? the plugs are both brown and idk about the colors...(car is at friends house, and i leave all stuff there) i would have to check it out later on today. is that what ur asking? or maybe what i said above
Old Jan 11, 2009 | 08:03 AM
Anyone?
Old Jan 11, 2009 | 08:05 AM
andoxviii's Avatar
If this was blue-taped to the fuse box, it is for OEM foglights.
Old Jan 11, 2009 | 10:44 PM
i checked out some 96 civic at junkyard. Seems like i plugged it in right. Anyone know if the plugs for the fusebox plug only on one spot, or is there a risk of plugging it in the wrong plug and have stuff malfunction/burn....
speedjunkie_g35
17
Oct 21, 2012 09:15 AM
Black Diamond
12
Mar 5, 2011 06:12 PM
JohnnyEF
Jul 20, 2010 07:50 PM
Marlon88
May 14, 2006 05:29 AM
InfamousRS
Jan 22, 2006 10:39 AM
