turn signals
Old Jan 10, 2009 | 02:06 PM
91blackEF's Avatar
Default turn signals
ok guys i asked this question before and dident get many replies so ill try again. my turn signal fuse in the kick panel (7.5) and the hazard fuse under the hood(10) keep blowing i replaced the hazard switch all the fuses and relays and im still have the problem i dont think its the hazards cause i can put a fresh fuse in and leave the hazards on no problems but when im out i can use the turn signals about 3 times maybe thats if im lucky before both fuses blow so im thinking at this point it has to be a short somewhere along the line but i dident know if the headlights and the hazards ran in circuit with each other seeing as they are seperate fuses but then agian its all the same bulb does anyone know a way i can fix this or check to see if its a short and how i can go about doing so thanks
Old Jan 10, 2009 | 08:31 PM
slvrlude's Avatar
Default Re: turn signals
hmmmm
Old Jan 10, 2009 | 08:38 PM
The_Honda_Guy's Avatar
You got told last time you check for shorts.
https://honda-tech.com/forums/showth...450&highlight=
Did you even do this? Most likely if you keep blowing the fuses you're shorting out the positive lead to ground and overloading the circuit. Get a multimeter and a wiring diagram and start tracing through. We cannot help you find shorts, you need to do it yourself.
Old Jan 11, 2009 | 01:43 AM
91blackEF's Avatar
thats not what i meant like when the car is off is there supposed to be a certain ohm running to the ground and power and when the car is on and the turn signal flashing what is supposed to be the power level then i know nothing about shorts and wireing
Old Jan 11, 2009 | 08:58 AM
Why don't you take it to a shop then if you know nothing about wiring?
Old Jan 11, 2009 | 09:40 AM
green99civic's Avatar
I would take the wire from the fuse test the voltage right were that (7.5) fuse is with a dvom test to see how much voltage you have. Then some where down the wire find a spot and test the voltage again if the voltage dropped significantly from the start then you defiantly have a short somewhere. I had the same problem with my left headlight it was much dimmer i found out that part of the positive wire to the bulb was corroded. If you live in weather were there is now then most likely it is corroded... hope that helps
Old Jan 11, 2009 | 10:43 AM
91blackEF's Avatar
alright thanks and im not going to take it to a shop pay 300 for something thats probably an easy fix isnt that what this forum is for anyway. ive seen people explain to people how to do a whole motor build but ive had one person tell me how to check for a short like i asked. and thank you
Old Jan 11, 2009 | 05:55 PM
ya np buddy. I agree with that i deff wouldn't go spend that type of money when it usually is something little and stupid the problem is just finding the short good luck..
EM2_PLo
Honda Civic (2001 - 2005)
Jul 19, 2010 12:54 PM
Masho
Jul 17, 2010 02:24 PM
k20eklipse
26
Jul 12, 2010 08:55 PM
KGB_JDM
Apr 9, 2010 08:51 PM
O16581724 5 2 5
Oct 6, 2005 10:03 PM
