d16z6 turbo build
I'm having to rebuild my d16z6, so I was thinking while it's all apart I might as well build it into a turbo. I was wondering what are some good internals to put in it so I could run between 10-20psi? Any input is much appreciated! Thanks
do not buy ebay vitara pistons...there is already companys making knock off vitara pistons which are not the same quality as on here in the FS forum...on the response to the running 10 to 20 psi you realize theres a difference in running the same amount of boost on different size turbo's...if you do go vitara with some tuner toy rods or something you would have to get your motor honed over to 75.5 bore size...my advice look at the single cam forced induction forum
Benson Withers
Jul 30, 2017 05:24 PM
