Piston help
Old Jan 10, 2009 | 11:50 AM
cuzzfolk99's Avatar
Default Piston help
hey guys i have a set of srp pistons for a b16 with a comp ratio of 8 8 1 and they are .020 overbore pistons. also a set of eagle rods for a b18 i was wondering would these parts work in a b18b ls motor if so im making a ls vtec
Old Jan 11, 2009 | 04:52 AM
cuzzfolk99's Avatar
Default Re: Piston help
bump ttt need help asap
Old Jan 11, 2009 | 08:00 AM
NJIN BUILDR's Avatar
The srp pistons will work fine,and will give you a touch higher compression.As long as the b18 rods are ls and not gsr/itr they will work.B18a and b are the same rods,b18c are different.
Old Jan 11, 2009 | 11:56 AM
cuzzfolk99's Avatar
sorry that was a typo i have the b16 rods as well will these work?
Old Jan 11, 2009 | 03:19 PM
The b16 rods are a different length and will not work with a b18 crank,block and the pistons you have.
the DA in HONDA
Mar 7, 2005 08:59 PM
hybridpatient95
Feb 9, 2005 04:45 PM
specie
Oct 13, 2003 11:34 PM
Goldfingiz
Nov 24, 2002 04:42 PM
