99' civic si headlight problem!!!!!!
Old Jan 10, 2009 | 09:51 AM
gotablk95gsr's Avatar
Icon2 99' civic si headlight problem!!!!!!
I am having a problem with turning my headlights on, when i turn the switch to turn on the headlights, they will not go on, but regardless of whether or not i flip the switch back and forth, the parking lights stay on. this is really pissing me off, so if anyone can help, please.......let me know!
Old Jan 10, 2009 | 11:09 AM
Unseen Racer's Avatar
Default Re: 99' civic si headlight problem!!!!!!
fuses?
the bulbs them selfs?
ground wires?
bad switch?
check all these
Old Jan 10, 2009 | 11:59 AM
redsidriver's Avatar
i have that same problem i think the switch in the steering column is bad luckily i have a relacement in storage
Old Jan 10, 2009 | 12:09 PM
NOFX's Avatar
H-T White Ops
I'd bet it's the switch. They're pretty easy to remove. Two or four screws. Then pull the switch out.
Old Jan 10, 2009 | 12:10 PM
raidacaipo's Avatar
did you do anything to your wiring that your not telling us about? did this just happen out of the blue? when you say your parking lights turn on what do you mean? are you talking about the rear parking lights? like the brakes and turn signal lights?
Old Jan 10, 2009 | 06:17 PM
thanks guys. i appreciate it...
Old Jan 10, 2009 | 07:45 PM
hondafab19's Avatar
you should definitely check, all your fuses
relays , and maybe wiring......
Old Jan 10, 2009 | 09:14 PM
The_Honda_Guy's Avatar
I'd go with multifunction switch like NOFX said.
I8Stang
Mar 12, 2009 09:41 PM
31flavorscivic
Dec 17, 2008 11:01 AM
jArceo
Feb 14, 2006 11:25 AM
MugenHonda
May 30, 2005 08:29 AM
Zubz
Oct 12, 2002 07:51 AM
