Full Race Turbo Kit & Built LS VTEC motor
Hey honda-tech, these parts only have 100 miles on them! minty fresh parts
NOO low ballers
Full RACE TURBO KIT B series
Only 100 miles on kit!!! $4,000 w/ 750 injectors pretty firm, plus a jeff evans base tune to run the 750s on
Fully 1600 ceramic coated manifold, downpipe, dumptube
custom full 3 inch garret 60 trim turbo
full race downpipe
full race Manifold
tial 44mm wastegate v band
tail blow off valve
full race front mount back door intercooler
full race intercooler piping fully polished
all t clamps
full race dumptube
full race oil line
custom return line
LSVTEC LONG Block!!!!!
longblock and 3 inch exhast ,all the parts and the motor only has 100 miles on it $ 4,500 firm
Ls bottom end
golden eagle rods
wiseco pistons
golden eagle main girdle
golden eagle block gaurd
Toda timing belt
brand new type r oil pump
brand new oil pump
Gsr head
Ctr intake cam
gsr exhast cam
brain crower dual valves springs
oem valves
aem cam gears
ngk spark plugs
dizzy has very low miles
arp head studs
Edalbrock victor x intake manifold
blox 72mm throttle body
omni 4 map sensor
stock injectors
stock axles
stock half shaft
hasport motor mounts
Full 3 inch k teller exhast to a 4 inch turn down exhast
aem fuel rail
aem fuel pressure regaultor
benen fuel rail
stock map sensor
alternator
golden eagle ls vtec conversion kit
hondata intake manifold gasket
slim fan
blue samco hoses
ebay half rad with arc cap
integra type r throttle cable
Tranny
Gsr tranny with around 25,000 miles, minty fresh trans!!!
Stage 5 competion 4 puck clutch , has 100 miles on, only broken in!!!!!!
Custom stainless steel clutch line for nice wiretuck!!!! sick as hell
gsr starter
500whp axles with a upgraded half shaft!!
$1100 picked up!!! firm
NOO low ballers
full race downpipe
full race Manifold
tail blow off valve
all t clamps
full race dumptube
full race oil line
custom return line
Ls bottom end
golden eagle rods
wiseco pistons
Toda timing belt
brand new oil pump
Gsr head
Ctr intake cam
gsr exhast cam
oem valves
aem cam gears
ngk spark plugs
arp head studs
omni 4 map sensor
stock injectors
stock axles
stock half shaft
aem fuel rail
benen fuel rail
stock map sensor
alternator
slim fan
blue samco hoses
Tranny
gsr starter
buy the turbo kit!! and full longblock w. the trans, i want this stuff gone but no lowballers!! i want a evo asap and i need to sell to buy evo so hurry up and buy
Turbo Parts HERE!!!LS/VTEC motor, Full Race IM w/ BBK TB, Comp twin disc clutch, Precision AR.70 tur
attentionwhore
Mid-Atlantic (Sales)
17
Feb 18, 2007 04:54 AM
TW: Baller Full race parts STG 3GT kIT,Built block,PNP HEAD,EF TRACTION BAR,MOROSO,MSD,AUTO METER AN
b18sihatch
Feb 6, 2007 07:25 AM
