D4 gear indicator doesn't work???
Old Jan 9, 2009 | 09:56 PM
hermtm2's Avatar
Default D4 gear indicator doesn't work???
Hi.
I have a 2000 EX which is 135k on it. I replaced my battery 2 days ago. After that the stock radio want me to put in security code which I don't know. I took the gear box out to clean aroud while the radio was disassembling to find serial No. After I got the number and cleaned them up, everything was put together. Also ATF was changed tonight.
After all jobs were finished, the gear indicator doesn't work nomally. Especially D4 doesn't turn on. No blinking and CEL. I can't see anything wrong. What is the problem?
Thanks.
Old Jan 10, 2009 | 02:34 AM
Former User's Avatar
Default Re: D4 gear indicator doesn't work???
The bulb may be blown.
Old Jan 10, 2009 | 07:11 AM
hermtm2's Avatar
What kinds of bulb should I buy? How the cluster can be taken out?
Thanks.
Old Jan 10, 2009 | 07:33 AM
I was wrong. The D4 indicator light in the dash is part of a printed circuit board. If the D4 light specifically doesn't work, then you would need to replace the entire circuit board ($55 @ Majestic Honda).
Old Jan 10, 2009 | 11:23 AM
hermtm2's Avatar
Thanks for diagrams.
I found a bulb for the D4, so I would like to try to replace the bulb.
I will take some pictures while doing the job.
Thanks.
steve061174
Honda Civic (2001 - 2005)
Oct 28, 2018 07:53 AM
Joyce
Dec 29, 2009 03:16 PM
toyonda
Feb 23, 2009 08:08 PM
day_your
Oct 8, 2007 09:42 AM
DAISIE'SACCORD
Jun 14, 2007 12:04 PM
