oil change question
your engine doesn't get used to it.. what do u mean by bad oil? if you mean non-synthetic oils, by no means are they "bad" as long as they are the correct weights the oil should still do its job.
improper lubrication = friction = heat = problem
Alright thanks i just meant old oil and i read up somewhere your engine can get a leak from new oil if its used to old oil
i put 5w-30 in it today so it should be good
thanks
craig
thanks
craig
Some people say that synthetic can cause seals to leak if you switch over from using dino oil for a long time, but that is just here-say for the most part. Leaking has nothing to do with how old the oil is...the older the oil is the worse it is on your engine.
tensai717
Dec 9, 2001 03:49 PM
