Difference between 88 and 90 engine harness
Old Jan 9, 2009 | 05:41 PM
freedm's Avatar
Default Difference between 88 and 90 engine harness
I have been asking this question for quite a while now and a I never seem to get a clear answer.....I wonder if anyone truely knows!!
What is the difference between a 88 CRX DX engine harness and a 90 CRX DX engine harness...
I have been told that there are minor differances but they can't tell me exactly what they are...
Free beer tomorrow to anyone that can answer this with backup!!
Thanks
Old Jan 9, 2009 | 05:46 PM
CRX Toad's Avatar
Default Re: Difference between 88 and 90 engine harness
Well technically there was no "DX" in the CRX model line. It was CRX HF, CRX, CRX Si.
Old Jan 9, 2009 | 05:48 PM
freedm's Avatar
so you too cant answer me!!! HAHA you know what Im talking aBOUT eveyone calls it a DX
Old Jan 9, 2009 | 05:51 PM
Deetz's Avatar
Crazy Honda Guy
In Canada, there were only two models....
crx (dx)
crx si
As far as i know, the engine harness's are the same. (dx to dx)
Old Jan 9, 2009 | 05:55 PM
freedm's Avatar
Thanks Deetz..
anyone have a different theory? I'm trying to plug a 88 harness (as soon as it arrives)into my 90 crx ...DX
and I was wondering if I was going to run into any trouble. Has anyone done this..or close to this with different year crx harnesses?
Old Jan 9, 2009 | 06:10 PM
ef yu's Avatar
not sure but i believe canada crx (dx) are mpfi.
that could cause some confusion. but op, since you already purchased(assuming you already bought it) try it. engine harness isnt to hard to change out.
Old Jan 9, 2009 | 06:14 PM
freedm's Avatar
Word...Good Point! The US is deffinatly dual point... with that in mind waht other differances could there be between US harnesses?
thanks ef yu!!!
ef yu's Avatar
btw, 99% of ht user refers the 'crx' model to the dx. why? so theres no confusion and questions of "what model is it? hf? si?
Old Jan 9, 2009 | 06:16 PM
freedm's Avatar
Thanks again ef yu...if you told someone outright that you had a crx...thier first question would be .."Which Model?"...this is just a given isn't it?
Old Jan 9, 2009 | 06:24 PM
Deetz's Avatar
Crazy Honda Guy
No! Canada got the same crappy 1.5L with dpfi on the dx model
Only the Si had mpfi here
Old Jan 9, 2009 | 07:12 PM
freedm's Avatar
So in great response of all crx lovers....no one can tell me for positive if there is a differance between any year crx harness....CAN THEY?
Old Jan 9, 2009 | 07:15 PM
Deetz's Avatar
Crazy Honda Guy
The true answer is super easy to find out........
Call any Honda dealer, ask them for the part number for the engine wire harness from both years. Same? there's your answer
Old Jan 9, 2009 | 07:20 PM
freedm's Avatar
good idea...don't know why I didn't think of that!!..but thats why we have forums..right?
I would have hoped for a better response turn out though..I'm sure I'm not the only one who has had to go through this issue!..wouldn't you think?.. I totally don't think anyone completely knows..but as soon as I find out I will post a headline to all CRX lovers all the info I aquire!!!..Thanks again DEETZ and EF YU ...You both are the real thing!!
God Bless
Old Jan 9, 2009 | 07:21 PM
EFRue57's Avatar
they are the same
Old Jan 9, 2009 | 07:25 PM
freedm's Avatar
Hey
EFRue57
any proof to go by? have you done this swap?
Thanks a million!!!
Old Jan 9, 2009 | 07:32 PM
EFRue57's Avatar
the engines are exactly the same. every sensor is in the same location, every sensor has the same amount of wires and the wires are in the same location. the ecu's are the same. Honda wouldn't have changed the harness while still using the same parts from the different year models.
there are differences in say the cluster harness and in parts of the chassis harness but it's not where the wires meet but the connectors themselves. but again that's mainly with the cluster. i'm trying to think of any other's but am not coming up with anything off the top of my head.
Old Jan 9, 2009 | 07:35 PM
freedm's Avatar
once again I agree..It seeems so simple a question. Like you said the engines haven't changed. The only other question left would be...Did the wires in the harness change colors? This may be valuable info while doing the swap. I have the 90 electrical manual but not the 88, so I'm not sure...any idea?
Old Jan 9, 2009 | 07:38 PM
EFRue57's Avatar
why do you have to worry about wire colors? are connectors missing? if not then just plug in the connector where it goes. the color of the wire doesn't change anything as long as you're getting the correct signal from point a to point b.
Old Jan 9, 2009 | 07:45 PM
freedm's Avatar
I'm sorry EFRue57 , i failed to mention that I'm swaping a 94 JDM GSR into this 90 CRX, and well...you can imagine. I have motor and 94 GSR harness but not the orginal 90 car harness...all I could find is a 88 CRX harness..Thats where all these questions stimulate from..But I couldn't come right out and ask that (because I've tried). I had to step back and ask more simple questions to get any kind of response...I guess I was asking too much at one time!!
Old Jan 9, 2009 | 07:47 PM
freedm's Avatar
by the way...sweet pic by your name!!
Old Jan 9, 2009 | 08:13 PM
EFRue57's Avatar
thanks...........i like it too.
Old Jan 9, 2009 | 11:14 PM
93formula's Avatar
yes the dx harness will be the same from 88-91....its real simple take the 88 harness, convert it to mpfi, put it on your gsr, bolt it in and call it a day...the majority of your problem will be de pinning and re pinning the new pig tails for the obd1, but im sure you will be able to figure it out...lets just say the 88/90 dx harness questions will be the least of your worries....good luck with the swap!!
Old Jan 10, 2009 | 08:43 AM
freedm's Avatar
thanks 93formula!!!
That was a hard question for some, huh? Luckily I have the obd1 jumper harness so everything should go smoothly. Thanks again!!!
Old Jan 10, 2009 | 11:01 AM
93formula's Avatar
no problem, yeah the jumper will make it a lot easier, you will have to repin the dist wiring, its in the faq though at the top of our forum.
Savtec-rex
Feb 23, 2014 08:58 PM
Junkyard
May 20, 2011 04:43 PM
xymantec
Apr 22, 2011 09:23 PM
Tyson
13
Oct 28, 2004 03:04 PM
