when do i need to replace suspension bushings?
Old Aug 5, 2002 | 07:30 PM
Bonga's Avatar
Default when do i need to replace suspension bushings?
as title,
Am i suppose to replace them when my car hit 100K miles?
or what kinda road test should I perform to see if these bushings are still good? like go over a bump and watch for un-normal vibration?
someone please fill me in
Old Aug 5, 2002 | 09:55 PM
Quik89Si's Avatar
Default Re: when do i need to replace suspension bushings? (Bonga)
Only reason most ppl replace these is to increase performance...there's no checkbox on the "maintenance schedule" for suspension bushings. If you want better suspension feel though, replace the bushings with some good polyurethane ones.
Alex
Old Aug 5, 2002 | 09:58 PM
POLLO's Avatar
Default Re: when do i need to replace suspension bushings? (Quik89Si)
Well, im not too sure if that will cure what you are going thru. But when changing your stock bushings the ride will be stiffer you will be able to feel the road, the car will handle great but it wont' be and air suspension quality type of deal.
Old Aug 5, 2002 | 10:00 PM
joeseph's Avatar
Default Re: when do i need to replace suspension bushings? (POLLO)
https://honda-tech.com/zerothread?id=246233
two bushing threads running simultaniously
Old Aug 6, 2002 | 06:51 PM
Bonga's Avatar
Default Re: when do i need to replace suspension bushings? (jcnfh)
thanks for the link. I m thinking changing bushings becuz my car rides like ****. Everytime it go over a bump, the steering wheel rotates almost 90 degree by itself. something is just not right.
The link you provided is helpful. Looks like lots ppl dont like the crappy ride after bushings installed. Maybe i should better off go with OEM bushings.
thanks guys.
lildragon'07
Oct 30, 2012 10:13 PM
Historyg
10
Dec 17, 2007 01:01 PM
VTi NA
Suspension & Brakes
Jun 20, 2005 07:23 PM
jdmcivicferio
Dec 22, 2002 08:07 PM
