Question regarding 94-01 Integra OEM Shocks
So i found someone that is willing to do the labor of installing some stock shocks back on my 97 integra for $80. Now all I need is the stock shocks.
He mentioned that I can use some civic shocks if I can't find integra but mentioned they are little more bouncy than Integras. Is that true?
And what year Civic should I be looking for? I'll be doing my search on craigslist over the weekend. Some advice would be appreciated.
92-95 civic, any model. using civic struts will allow for a bit bouncier ride, but theres not a huge difference. new civic truts would feel like old integra struts. if you use integra springs, you should be okay. if you are talking about a direct bolt-up, i think the car may be a bit low on civic springs
So now that you mentioned it, I guess I should stick to Integras since Civics may keep my car below stock height.
I believe the struts are identical, its the springs which have different springs rate that will give you a bumpier ride since the integra rates are stiffer.
idrincwater
Jun 12, 2004 10:25 AM
threatcon13
May 22, 2004 03:55 PM
