How do you remove the ac/heater box?
Old Jan 9, 2009 | 10:14 AM
dc2teg2006's Avatar
Default How do you remove the ac/heater box?
I can't take out the middle box where the hot/cold air come out of. pic is here
Old Jan 9, 2009 | 11:19 AM
dc2teg2006's Avatar
Default Re: How do you remove the ac/heater box?
anyone?
Old Jan 9, 2009 | 11:23 AM
redGSRguy's Avatar
There are some hoses in the engine bay, did you take those off?
Old Jan 9, 2009 | 11:26 AM
dc2teg2006's Avatar
there is a medal tube that is connected to the box, but i can't figure how to take that off, it underneath the box, other then that there is no tube connecting if from the engine bay.
Old Jan 9, 2009 | 11:38 AM
sackdz's Avatar
remove the two a/c coolant lines and the two heater hoses from inside the engine bay. disconnect temp sensor. unbolt the box, pull out of rubber firewall seal.
Old Jan 9, 2009 | 11:41 AM
ruffrhyder's Avatar
You're confusing that box with the evaporator.
Old Jan 9, 2009 | 12:02 PM
dc2teg2006's Avatar
I remove everything that was attached to the box.
then i remove three medal screws
I try to ****** it off after that, but still it wont budged. What else im a missing? I dont see any other screws.
that hose that i the circle in the first pictures, is underneath the box. how do i remove that? it seem like it come out with the box too.
Old Jan 9, 2009 | 01:04 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I think you forgot to remove the nut from the stud that sticks through the firewall, near the heater hoses.
Old Jan 9, 2009 | 11:52 PM
vietnamezerice's Avatar
it should be right above and little to the left of the heater hoses if you're looking from the engine bay.. a 12mm
Highny
Feb 22, 2016 12:42 PM
gmclb7
May 8, 2013 06:52 PM
Choy
Mar 28, 2010 01:56 PM
Nat X Stl
Jul 26, 2007 05:59 PM
