DPFI to MPFI & CA Smog
Old Jan 9, 2009 | 09:28 AM
CW-ITR's Avatar
Default DPFI to MPFI & CA Smog
For those that done this mod, what happened when take your car to smog?
Old Jan 9, 2009 | 10:42 AM
hondacivic90zc's Avatar
Default Re: DPFI to MPFI & CA Smog
the smog guy didn't say anything to me when i got a smog with my dx hatch, which i swapped a sohc zc into and converted to mpfi. I think the main thing is to make your wiring, vacuum lines, etc. look as stock as possible so that the smog tech has no reason to question it. Personally i switched over to a full si harness(under dash and engine) so mine looks as factory as it gets. The wiring harness swap is kinda a pain but well worth it i think.
Old Jan 9, 2009 | 12:27 PM
CW-ITR's Avatar
^ Thanks for the info. With what you aid, the swap/mod doesn't effect or change the number or the way it is smog. So, visual inspection is what I need to worry about.
Efbucket
14
Oct 5, 2007 03:14 PM
SoCalRacer
22
Aug 1, 2004 03:44 PM
92civic_si
24
May 24, 2004 09:05 AM
dcvt16
Apr 24, 2004 10:05 AM
