need some feed back on clutches!!
Old Jan 8, 2009 | 09:43 PM
ciiivic89's Avatar
Icon6 need some feed back on clutches!!
i have an 89 honda civic hatchback si all stock and my clutch is going out i wanna get it replaced but i wanna know what you guys think stay with a stock clutch or invest in an up-grade like stage 1 does it make a diffrence also what about a lighten flywheel? im not planning on racing just daily driving!
Old Jan 8, 2009 | 10:49 PM
northemt88's Avatar
Default Re: need some feed back on clutches!!
Stage 1 is fine for DD, it usually costs about the same for stock or 1,2,3, i would say stay with the stock flighwheel
Old Jan 8, 2009 | 11:01 PM
acmoc's Avatar
yea, I have a exedy race flywheel. ou gotto rev the engine real high for it not to bog when you accelerate
Old Jan 9, 2009 | 02:04 AM
HumanResource's Avatar
for DD stick with a nice Daiken set
Exedy
just get the flywheel resurfaced
don't lighten
fawk all the exotic material
fawk pucks
you're left leg will thank you in traffic
Old Jan 9, 2009 | 07:46 AM
sanimalp's Avatar
$cat /dev/urandom
It really depends on how much time you spend in traffic.. if you are in a traffic jam once a week or more, then you probably should go no higher than a stage 1 aftermarket clutch. even still, a stage 1 on a stock or near stock car is more than enough to hold under just about any conditions.
I run a stage 1 and an 8lb flywheel in my DD.. but i live 5 miles from work and am never in a traffic jam. I am pretty tolerant of a car that is harder to drive though.. my wife won't drive my car because of how it is set up, but I like it.
Old Jan 9, 2009 | 12:00 PM
ciiivic89's Avatar
cool harley any traffic to and from work ill talk to my mechanic and order a stage 1 kit i will post the final result till then thanks for all your info guys!!!!! ciiivic89
Old Jan 9, 2009 | 12:22 PM
acmoc's Avatar
Is it hard to remove the tranny while the motor is still in the car?
Old Jan 9, 2009 | 01:32 PM
sanimalp's Avatar
$cat /dev/urandom
no.. you can leave the engine in and still remove the transmission. you just need a jack stand or emergency jack to hold the engine temporarily while the transmission is all the way out. you have to take off 3 of the 4 engine mounts to do it, hence the need for a jack stand to support the other side of the engine while the transmission is out.
Old Jan 9, 2009 | 01:34 PM
hybrid1990crx's Avatar
No its very easy. You just have to remove 2 mounts to let the trans drop down. Ive had the transin and out of a b series swapped ef in 3 hours my first time doing it ever.
I would go with a exedy stage 1 with your stock flywheel resurfaced.
DonReggeaton
18
Jun 10, 2009 03:11 PM
Duck Sauce
May 18, 2008 10:43 AM
preludeboybmw
Nov 13, 2007 06:27 PM
airikkCRX
Jun 12, 2005 07:41 PM
-=TWITCH=-
Apr 17, 2002 08:25 AM
