Universal hood hump/bulge/scoop
I've been searching forever and can't find anything decent.
I need to find some sort of universal hood hump(3" tall), to clear the engine in my Civic.
Anybody have any ideas? Would like a RS style scoop, but fully closed....just a really clean hump I can either weld into place, or bolt into place. I'd hate to have to make a custom fiberglass hood
Thanks!
Thanks!
Its so tough to find a clean hump....either super ricey or old school muscle.
This MAAAAY work
Or a roof scoop from AVS like this
No new pics...here's a vid. You can see how much I need
This car was very clean, OE Japanese parts and tasteful mods...used to have a Spoon hood, but that won't fit now. I want the hood to blend nicely, if possible.
This MAAAAY work
This car was very clean, OE Japanese parts and tasteful mods...used to have a Spoon hood, but that won't fit now. I want the hood to blend nicely, if possible.Trending Topics
there are lower oem intake manifolds off of j35 and j30 engines that might help out with clearance inssues, but I am not 100% sure about how much lower they will sit or possible performance advantages/disadvantages....
hope this helps...
hope this helps...
Yeah...the Odyssey uses the one piece plenum...it's all for different EGR passages and intake air butterflies... It'd be nice to get a custom hemispherical manifold made
i would say to measure where it is going to be on on the hood, then cut the section out of a stock hood, once the hood has a hole big enough to clear the motor, bolt the thing down then have a body shop custom fab a fiberglass hump over it that way it looks somewhat like the hump on an eclipse hood, just a big bump outta nowhere
yeah thats a vw engine my bad really similar looking tho but dude thats a serious bad *** swap! showed my guys this post mad respect yo good luck with the hood. I haven't found anything that looks like it will fit that. a custom one would be your best bet for sure, props bro.
VR6 in MK3 Jetta above fyi!
As far as the hood bulge, have you given any thought to chopping the bulge out of an 95-99 eclipse hood, maybe?
