brake lights wont go off
brake lights as in your taillights, then it would be your brake light switch which is the thing that is bolted directly above your brake pedal, 14mm nut holds it on so buy a new switch unplug the old one get a wrench and swap it out with new, let us know if this is ur problem, good luck
Alright ill see wassup,but let me start over,when brake pedal is pressed down the tail light doesnt brighten up it just staY on like when turning on the lights using the switch.it also stay on when the light switch is off and the key is out of the ignition. I have to disconnect the battery when i park,i checked the fuses already but didnt go through them one by one, imma do it today,and i topped off the brake fuild already too
i know what it is!!
your brakes are on.
u need this part right here.
Part number 27.
Attach to your pedal is that lil thing and that thing pushes against a "black button switch" and when u step on ur brakes, the thing Depresses/releasing the button and it activates ur brake lights
u can go under ur steering column and press it and have somebody outside telling u wsup.
your brakes are on.
Part number 27.
I have a fresh day today and it aint raining so imma work on my teg...did i tell ya i traded my ps3 for this 90 integra gs 4 dr, it just need a clutch,front, brake and axles thats it
Alight i know whats wrong just what rice said...it was that i guess black thing that pushes against the button on thebrake pedal...i looked and the brake pedal was not making contact with the button....right on for the input im off to the junk yard
disboiflaco
Mar 14, 2011 05:45 PM
musclehead954
Feb 27, 2008 10:28 AM
crxtreme27
Apr 20, 2003 01:37 PM
