Axle?
Not really man.
Have you tried standing on the breaker bar? I've had to do that a number of times and they finally came off. You could always go down to a shop and have them buzz them off with a 1/2 inch impact wrench. Then just tighten them down and you'll be able to pull them off with your breaker bar once you get home.
Good luck. those guys are bastards sometimes. lol
lol i would do that but i unplugged everthing took out my radiator expecting my axles would come out easy the bolts are on so tight or something theyll take my weight
Get a piece of pipe about 4 to 6 feet long. put that over your breaker bar and pull. That will get them off. Have a friend hold the socket on the axle nut to make sure it doesn't come of and round the nut.
i was using a big a** wrench on top of my breaker for a lil more strength ill try it again tom and hopefully i can get my shift linkage out and axles to get my engine pulled this weekend
You'll get it man. those two things suck, I've been there before many times, but you'll get em.
One thing you could try is to put the breaker bar on it and push the car and use the ground to hold the breaker bar. Then just push the car and the weight of the car will break that thing loose. Worth a try. I know how it is not having air tools.
it wasnt me it was my new honda buddy hes a big guy, https://honda-tech.com/forums/appearance-build-threads-122/my-new-project-91-ef-2382232/
elmalouno
Jun 2, 2003 04:29 PM
