89 crx si way too much fuel help
Old Jan 8, 2009 | 05:12 PM
cwf1988's Avatar
Default 89 crx si way too much fuel help
ok i have a 89 crx si with a d16b non vtec running a po6 computer, i got the motor in and when i crank it, it wants to start up but when it does it pushes alot of fuel out the header, (yes i am running a straight header) it just poring gas out of it and sometimes catches fire.. i check my fuel pressure i am getting 60 when it prims and 40 after the fuel pump primes. idk if its out of time or wat the deal is plx help
Old Jan 8, 2009 | 05:24 PM
EFSiR's Avatar
Default Re: 89 crx si way too much fuel help
way too much pressure, please clarify your engine model.
Old Jan 8, 2009 | 05:50 PM
cwf1988's Avatar
obo1 jdm d15b non vtec stock
Old Jan 10, 2009 | 10:20 AM
cwf1988's Avatar
need help here guys
Old Jan 10, 2009 | 11:27 AM
93formula's Avatar
are you using obd1 injectors?? resistor box??
Old Jan 10, 2009 | 08:21 PM
cwf1988's Avatar
obd1 injectors yes and i taped all the wires to the resitor box together any ideas
Old Jan 10, 2009 | 09:11 PM
93formula's Avatar
https://honda-tech.com/forums/showth...istor+box+obd1
go back to obdo injectors....obd1 injectors wont need the resistor box.
elmalouno
38
Apr 18, 2019 03:18 PM
ef9smashing
Aug 4, 2010 08:58 PM
646EG
Jan 22, 2008 05:12 PM
white90rexsi
Jun 22, 2007 06:21 PM
integraracing91
Aug 6, 2004 07:34 AM
