JDM swap question
Old Jan 8, 2009 | 04:19 PM
tmrtwo's Avatar
Default JDM swap question
Ok i did a jdm swap in my 4th gen prelude. Cant get it started 4 some reason. I was wondering do i need a jdm wiring harness because there is internal coil on the jdm motor vs the usdm? Any pointer on what to check would be great.
Old Jan 8, 2009 | 06:45 PM
thatsmyhonda's Avatar
Default Re: JDM swap question
on mine i just grounded out the plug for the internal coil...im not sure though if u need a different diatributor or not cause i think there is an xtra wire the usdm distributor
Old Jan 8, 2009 | 11:24 PM
red92si's Avatar
Just use a 30 amp fuse to jump the connector for "External Coil Power" if you are using the USDM wire harness and the JDM Internal Coil distributor.
Here's a pic of mine.
Old Jan 9, 2009 | 05:19 AM
bb4arson's Avatar
yes u need a need a different harness not a jdm one just a regular vtec harness if it was not vtec..
was it h23 ?
is it cranking at all?
Old Jan 9, 2009 | 05:21 AM
bb4arson's Avatar
nice never seen that done.
i just get those caps to cancel it out +)
Old Jan 9, 2009 | 05:27 AM
95ludeSE_bottle's Avatar
you cant use a jdm wiring harness on your car unless u have a right hand drive vehicle. i just did same swap on mine. u can take off the distributor on the jdm and use ur distributor off ur old motor- u just gotta mount ur coil somewhere in the engine bay. and since u'll be using ur wiring harness it will all plug up easily.
P.S. I have a question... does ur tach now work?? mine doesnt and i have no idea why??
Old Jan 9, 2009 | 10:54 AM
tmrtwo's Avatar
cool...yea it was a h23 harness from b 4....Im gonna try that fuse in the external ditrib connector. Hopefully this works for me. Yea n thats what i meant h22 harness....not jdm lol. Didnt know bout the clip on the harness because it has to send some kind of signal to the ecu.
stealth09
Oct 20, 2010 01:31 PM
shiux
Jun 19, 2010 08:04 PM
steveobb4
Mar 17, 2005 07:41 PM
auburnBoy
May 27, 2004 06:38 PM
CrazyHondaBoy
Jun 3, 2002 07:30 PM
