Carburetors for a civic?
I've often considered it. But if you cranked the fuel pressure down on a pump that's supposed to kick out ~35 psi, won't you burn the pump out? Do you remove the FI pump and get an external carbed pump?
what year of Civic are u talkin about? I already have a carb in my 86 and i am trying to figure out how to make it faster so i do not see the point of converting to carb in fact i am lookin at the idea of converting to FI to see if i can make my CRX faster unless someone suggests how to enhance my current carb setup
I'd think that on really built engines carbs could be beneficial, because there is no rev limit, you can tune them top run as rich/lean as you like, etc etc. Personaly, I'd never run a carb.
Dominic-CTR
Nov 16, 2003 10:53 AM
D16A6Turbo
Dec 3, 2002 08:57 PM
