B16 swap problems.......
Old Aug 5, 2002 | 06:01 PM
k4ff1n3's Avatar
Default B16 swap problems.......
my car is a 91 CRX si w/b16 and a y1 tranny. ok i got my engine swapped
and i started it for the 1st time today.......
1st im overheating bad,my radiator fluid is boiling fast and engine is
getting too hot 2 fast...
2nd i have a y1 tranny and 91 integra axles and when i started it my right
wheel started turning (i was in neutral)???????
3rd im idling too high 1500 to 2000 rpms, when i start it up it revs from
1000 to 2000 a couple of times and then the check engine light comes on
and it settles between 1500 and 2000 rpms
its throwing codes 1,3,and 5
if im leaving any info that might help out let me know
PLEASE HELP!!!!!!!!!!
Old Aug 5, 2002 | 07:00 PM
JV's Avatar
JV
Who?
Default Re: B16 swap problems....... (k4ff1n3)
Did you bleed it properly...?
Was the car on jackstands...? If so, that is normal...
Not a clue...
Old Aug 5, 2002 | 07:22 PM
k4ff1n3's Avatar
Default Re: B16 swap problems....... (JV)
well i didnt at first but i opened the rad cap after i overheated, and opened the spicket behind the block hope fully i got it all the air out. yeah it was on stands.....thats normal???
thanks for the help..........
anyone else got any ideas about my idle????
Old Aug 5, 2002 | 11:54 PM
Kamin's Avatar
pull that code
see what code is for the CEL
and yes its normal with the car on jack stands. thats the problem with a peg leg differental only 1 wheel gets power.
94eh2
May 11, 2009 08:02 PM
hondacivic00
Acura TL, RL & ZDX
Aug 21, 2007 05:21 PM
FriendshipExpress
46
May 3, 2002 02:34 PM
