Are 94-95 and 96-97 airbag modules interchangeable?
Just wondering if I can use a module from a 94 in a 97 accord? Will the connections fit and will it work the same? Thanks in advance for any help.
The passenger side DOES NOT interchange. I'm unsure of the driver's air bag. I know this from swapping interiors. The plugs do not match up. They install and look fine. The air bag just won't plug into the dash harness.
The airbags will fit. You will need to swap the plugs though. Not hard if you can solder. I did mine from my 95 into my 97. The airbag module (SRS) is year/model specific though. Cut plugs off of 94 and get plugs from 97 and solder them on.
