98-01 ls mesh tire size?
Old Jan 8, 2009 | 12:32 PM
absinthminded's Avatar
Default 98-01 ls mesh tire size?
Can i run 205-50-15 tires on the stock meshies? Tire rack said 195-55 -15 as oem but ive been reading that either one will work but not what rim size their working on.
Old Jan 8, 2009 | 12:34 PM
mrdeadman's Avatar
They let me pick
Default Re: 98-01 ls mesh tire size?
Yes. I like the 205s better. Except if it snows.
Old Jan 8, 2009 | 12:42 PM
92civic_hatch's Avatar
damn straight.
Old Jan 8, 2009 | 12:47 PM
mikeSONICGSR's Avatar
I had the same size on my GSR wheels and I liked them, and they worked okay in the snow just have to be careful.
Old Jan 8, 2009 | 01:14 PM
Ok sorry i jumped the gun asking this question, tire rack has some helpful tech articles. So 205-50-15 tires will fit a rim from 5.5 to 7.5" wide from what those size tire's rim width range is. Thanks
Old Jan 8, 2009 | 01:35 PM
xplosion79's Avatar
195/55 is pretty much the same height as 205/50 it's all percentages.
Old Jan 8, 2009 | 03:30 PM
N3GUM's Avatar
Usually the most common sizes are 195-205, so you will be fine!
Old Aug 30, 2010 | 08:22 AM
danedoremus's Avatar
so are these a 5 inch wide rim or 7 inch?
Old Aug 30, 2010 | 08:38 AM
p nut's Avatar
Stock LS/GSR/ITR rims are 15x6. I personally just get which ever is cheaper between the two sizes.
Old Aug 30, 2010 | 12:18 PM
Woodlock's Avatar
205-50-15 will work just fine, i actually just went from the 195-55-15 a week or so ago.
the 205's are actually more popular and you can get a better price usually in that size.
Old Sep 3, 2010 | 07:36 AM
nsxtasy's Avatar
H-T Order of Merit
It really depends on the tire. For example, the Yokohama S.drive, which is a very popular summer tire, is significantly less expensive in 195/55-15 than 205/50-15.
Old Sep 3, 2010 | 10:21 AM
dev203d's Avatar
Icon3 Re: 98-01 ls mesh tire size?
Yeah ur fine, the 15 is what counts, beware the tire will not only be wider, but thicker too, so you cant slam ur car as much. 205-50 is a ratio of width to height, not just 205=width and 50=height.
Old Sep 3, 2010 | 11:15 AM
nsxtasy's Avatar
H-T Order of Merit
Not true. The sidewall on the 205/50-15 is actually shorter than on the 195/55-15 (because 205*.50 mm is less than 195*.55 mm). The overall diameter of 205/50-15 is 1.6 percent smaller than that of 195/55-15.
In terms of clearance, they are usually pretty close, with the extra width of the 205/50 typically offsetting the larger diameter of 195/55.
Old Sep 3, 2010 | 01:42 PM
dev203d's Avatar
hmmm i guess, but when lowering the car, a 205/50 would prob lower the car to the same as a 195/55, or pretty close, where as a 205/45 would lower the car a lot more vs a 195/55.
Old Sep 3, 2010 | 07:24 PM
nsxtasy's Avatar
H-T Order of Merit
There's no such tire size as 205/45-15. If you're thinking of 205/45-16, that's about the same outer diameter as 205/50-15.
Old Sep 4, 2010 | 02:01 PM
dev203d's Avatar
It was an example, yeah I know theres no such size.
B_Swapped93
Nov 25, 2013 12:52 PM
Brewbot87
May 7, 2013 05:40 PM
em12nv
Mar 18, 2008 09:12 PM
hanskies
Jul 24, 2006 10:18 AM
still
Apr 7, 2006 02:35 PM
