after swap- no tach!?!?
Old Jan 8, 2009 | 08:05 AM
95ludeSE_bottle's Avatar
Default after swap- no tach!?!?
i just repalced my h23a with a jdm h22a- now my tach doesnt work- any ideas where to start looking for the problem? anyone experienced this before? thanks for any help
Old Jan 9, 2009 | 09:40 AM
Default Re: after swap- no tach!?!?
come on guys.... i know somebody has to have heard of this problem before... any ideas at all?
Old Jan 11, 2009 | 07:25 AM
Acidcrakker's Avatar
Follow the blue wire inside the dizzy, thats the one that will send a signal to your tach
Old Jan 11, 2009 | 09:49 AM
skrewdlude's Avatar
Also, near the passenger side wheel well ( in the engine bay), there is a capped blue wire. It is a test tach lead, check the voltage there, easier than pulling apart the dizzy usually.
Old Jan 11, 2009 | 10:25 AM
yah i finally figured out that that blue plug in on my wheel well was not for my vtec lol.....thanks JTC... im still trying to get my vtec to woking though... i now have a tach though.... i have read that some cars are prewired for vtec and i thought mine was (95 SE) but im trying to figure out where and what wires to hook to the op swith and solenoid..... that is how to hook it up without going thru the fire wall with new wires...and i may not can do that but it was just an idea.... if im wrong somebody tell me please.....
p.s. this h22 pulls harder than my h23 with out the vtec working... i cant wait to feel it in full effect....
Old Jan 11, 2009 | 10:44 AM
You are going to have to go through the fire wall, its not as hard as you make it out to be.
If you want an easy way to wire vtec on this motor, you can do this.
Run the Vtec oil pressure switch in the vtec solenoid wire. As long as there is oil in there it will work for you.
The vtec oil pressure is like D7, and the soleniod is like a7(those arent the correct plugs, Ill leave that up to you to figure out. So just plug D7 into the a7 line and you will be good to go.
Note that you are still going to have to run a wire from the ecu a7 into the engine bay and plug it into the Vtec solinoid
battleREADYb20
Aug 21, 2008 08:53 AM
E.F.Honda
Apr 24, 2008 05:07 AM
CLE
12
Oct 31, 2007 07:31 PM
prelude_93vtec
Jun 28, 2007 03:00 PM
Mikey3000
Sep 6, 2006 02:32 PM
