horn does not work, clockspring has been replaced
Old Jan 7, 2009 | 06:07 PM
hpi247's Avatar
Default horn does not work, clockspring has been replaced
alright here it goes...
background info...car is a 1994 civic dx manual. while installing an alarm, i took the entire dash and steering wheel off. after i put everything back together, i later realized the clockspring wasnt right. i was actually parking at the mall and heard the clockspring stretch and break...so i knew why my SRS light was on and the horn wasnt working.
i bought a new clockspring off ebay. now my only quam with this one is that it was listed as it came off a car with cruise control and i do not have cruise control as my car is a dx model. are all the clocksprings the same? or vehicle specific for with/without cruise control?
what i have done...
-i have tested the horn with direct power and it does work.
-i have checked fuses and all appear fine.
-i have tested for continuity between point A and B on the relay.
now, i tried checking for continuity between the plug that connects to the relay and the single wire plug that connects to the horn within the steering wheel and i was NOT able to achieve continuity. i believe this was an accurate test because now my suspected problematic clockspring could be the point where contact was lost.
so my questions...
-are clocksprings specific to vehicles with and without cruise control? i suspect no because my original clockspring has an unused plug, which im assuming is for cruise control.
-anything else i can test for?
thanks in advance for any input or discussion anyone can provide.
Old Jan 18, 2009 | 09:21 AM
hpi247's Avatar
Default Re: horn does not work, clockspring has been replaced
found my solution and figured i would post it for reference. my car is not equipped with cruise control, thus i needed a clockspring for a car without cruise control. everything is copacetic now.
buff1110
41
Jun 27, 2016 07:06 AM
Rob_KCMO
Apr 21, 2010 08:33 AM
hpi247
Jan 18, 2009 09:21 AM
Langsta
Dec 22, 2006 05:32 PM
khead69
Feb 15, 2002 11:29 AM
