fitting needed fof oil pressure sending unit
Old Aug 5, 2002 | 04:31 PM
SOHC_power's Avatar
Default fitting needed for oil pressure sending unit
O.K. I posted this in the civic forum, but no one bothered to reply. I have a d16y8 motor and I need to know what adapter, or what size the hole in the block is so I can get the sending unit from an autometer guage to fit. I called autometer's "tech" support, and they told me to call honda. Any thing would be greatly appreciated. Thanks
[Modified by SOHC_power, 7:31 PM 8/5/2002]
Old Aug 5, 2002 | 07:50 PM
Malice's Avatar
New User
Default Re: fitting needed for oil pressure sending unit (SOHC_power)
they use the same fitting for nitrous installs. go to ur local speed shop and ask for the fitting.
Old Aug 5, 2002 | 08:05 PM
tinkerbell's Avatar
you might possibly need a:
1/8 BSP male to 1/8 NPT female adaptor
check the instructions...
t..
Old Aug 5, 2002 | 08:06 PM
tinkerbell's Avatar
Default Re: fitting needed for oil pressure sending unit (tinkerbell)
PS
it is recommended to run an oil line and position hte sensor off hte block to prevent damage to the blocks thread...
Old Aug 5, 2002 | 08:09 PM
carl_aka_carlos's Avatar
PS
If you don't do it that way...you'll have happen to you what happened to me...I had a fitting break off, sprayed oil everywhere! definetly buy the stainless steel braided line from autometer...it'll work with their pressure sensor unit, and mount the unit on the firewall
Old Aug 5, 2002 | 08:29 PM
raene's Avatar
Default Re: fitting needed for oil pressure sending unit (carl_aka_carlos)
Check The Old One, they have a how-to on there that I followed when doing mine.
Old Aug 6, 2002 | 02:41 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: fitting needed for oil pressure sending unit (raene)
see new images below
[Modified by Mista Bone, 4:44 AM 8/7/2002]
Old Aug 6, 2002 | 05:29 AM
SOHC_power's Avatar
Default Re: fitting needed for oil pressure sending unit (Mista Bone)
thanks again mista bone...and everyone else too
[Modified by SOHC_power, 8:36 AM 8/6/2002]
Old Aug 6, 2002 | 08:07 AM
Speed PHreak's Avatar
even better than better
Not to ***** on your pic, This is my setup for my turbo car.
Old Aug 6, 2002 | 09:37 AM
WOTTEG's Avatar
Default Re: fitting needed for oil pressure sending unit (Speed PHreak)
That's my pic everyone is using. I shouldh've put my name on it. . . .
And it's BSPT, the T is for tapered.
Old Aug 6, 2002 | 01:10 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: fitting needed for oil pressure sending unit (WOTTEG)
put you name on it and send it to me,
Old Aug 7, 2002 | 12:42 AM
Mista Bone's Avatar
D Tranny Guru
Are these acceptable WOTTEG and Speed PHreak?
Old Aug 7, 2002 | 05:02 AM
Ha ha ha....*click right, save as*......I doesn't bother me a bit
Old Aug 7, 2002 | 06:03 AM
WOTTEG's Avatar
Perfect, I have the original PS document at my house, no internet there though.
only at work) I'll send you another version here soon Mista Bone.
VitaD16
Mar 13, 2014 11:28 PM
zbower7
May 14, 2004 01:42 PM
integranator
Apr 24, 2003 09:42 PM
blufke
Nov 12, 2002 03:20 PM
2k1_ITR_0736
Aug 8, 2002 07:20 AM
