Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
how to disable AC on defrost?
Old Jan 7, 2009 | 04:18 PM
rice4life's Avatar
Default how to disable AC on defrost?
how do i disable or turn off the auto AC when the vents are set on defrost mode? i would like to be able to turn the AC on/off manually.
i followed these instruction for 01-03 civic but it didn't work for my 06.
http://groups.google.com/group/rec.a...6c853dbb7a8a41
(1) Turn Car Off
(2) Turn Temperature **** To Full Blue (All the way to the left -Counter-Clock Wise)
(3) Turn Vent **** To Off (All the way to the left - Counter-Clock Wise)
(4) Hold Down Air Recirculation Button As Well As A/C Button. NOT THE DEFROSTING BUTTON.
(5) Turn the car on to two (ll) . The recirculation blinks ONCE and the AC blinks once.
You will now have control of your A/C regardless of what setting you
are in, to revert back, simply repeat the procedue.
Make sure u hold on to the two buttons before u turn on the car. Hold
it till after the AC button blinks. The recirculation button blinks
first than the AC. Make sure ur not holding on the Defrosting button
for the rear window
Old Jan 7, 2009 | 04:39 PM
rice4life's Avatar
Default Re: how to disable AC on defrost?
i figured it out.
first, you have to turn the ignition on and select the Panel only vents button (the far left one) then turn the ignition off and back on while holding the Recirculation and A/C button down for about 7 seconds. the Recirculation light will blink several times then the A/C light will come on and you are set. Also, make sure the temp **** is full cold and the fan **** is off.
now when you select defrost, the A/C will automatically come on (the AC light will come on also) but you can push the A/C button to turn it off, just like earlier Honda model.
Old Jan 8, 2009 | 08:18 AM
erie's Avatar
HOLY CRAP that worked! ! Thank you so much for this, Ive hated the AC on all the time, and now I can turn it off.
Old Jan 8, 2009 | 08:22 AM
civicguru's Avatar
good good will switich mine as well.................excellent
Old Jan 8, 2009 | 08:39 AM
bizzybear's Avatar
you know i never understood this question because my car always worked where i can turn the AC on/off at the push of a button...
Old Jan 8, 2009 | 10:38 AM
cbstd's Avatar
The factory makes the A/C come on when you turn on the defroster for a reason:
Among other things, the A/C dehydrates the air (takes all the moisture out) and so your windshield drfrosts that much quicker using the A/C.
Running the A/C on a regular basis is a very good idea for any car and hondas in particular. If the A/C compressor does not get much use, the seals dry out and the refrigidant will leak.
Old Jan 8, 2009 | 11:02 AM
SIVIC 3's Avatar
dont you just hit the a/c button to turn it on/off?
Old Jan 8, 2009 | 11:18 AM
Zeusone's Avatar
its set to be on all the time from the factory. once you turn it off you gain a couple mpgs.
Old Jan 8, 2009 | 12:33 PM
K5^'s Avatar
K5^
Brand New
I originally thought the same but soon figured out that the ac continues to cycle after pressing the ac to off.
Old Jan 8, 2009 | 12:39 PM
av911's Avatar
IIRC,
From the factory, if you turn the fan on AND put it in defrost, the A/C will turn on the but the green light on the A/C button does not lit. In order to turn the A/C off, you'll have to press the A/C button twice. Press it the first time, A/C button will be light up. The second time will turn off the A/C.
The OP's procedure on how to turn it off will make the A/C button light up when you turn the fan on and put it on defrost. After completing the procedure, you'll only need to press the A/C button once to turn it off.
Old Jan 8, 2009 | 01:48 PM
K5^'s Avatar
K5^
Brand New
Originally Posted by av911
IIRC,
Sorry I'm not exactly following. Wouldn't you have to press it 3 times? When you first turn on the defrost, the AC will light, press it once (first time) the light will turn off. Press it again (2nd time) the light will turn on. Then you would you press it again (3rd time) to turn it off.
rice4life's Avatar
the AC will still come on when you select defrost but you have the option to turn it off. older hondas used to be like that but not the newer ones. you don't always need the AC to defrost the car, especially in the winter when outside air is usually more dry and also when you're on the highway where fresh air is moving through the cabin.
Old Jan 8, 2009 | 01:50 PM
rice4life's Avatar
IIRC,
i didn't know that you could turn the AC off by pressing it twice, without disabling auto AC. i couldn't tell base on the AC light because i knew it was on even though the AC light was off, when defrosting.
at least now i just have to press the AC button once to turn it off.
Old Jan 8, 2009 | 01:54 PM
rice4life's Avatar
i think he was saying that you press the AC button twice to turn it off if you don't have the auto AC disable. but when you disable the auto AC, then you just have to press the AC button once to turn it off, also the AC light will come on.
Old Jan 8, 2009 | 02:17 PM
av911's Avatar
From factory, if you turn on the fan and press Defrost, the A/C will automatically turn on. In order to turn it off, you press it twice.
Old Jan 9, 2009 | 07:04 AM
SIVIC 3's Avatar
sounds like a big waste of time to me. not worth the hassle. just let the car do its thing man.
Old Jan 9, 2009 | 07:35 AM
FijiBlueFG2's Avatar
Road House
Open the window
/thread
MattBernazzoli
Feb 1, 2010 04:28 PM
GsrVtec
Jul 7, 2006 03:14 PM
Luchini
Apr 15, 2004 02:25 AM
