Headlight Out
Old Jan 7, 2009 | 11:00 AM
awdgsx96's Avatar
Default Headlight Out
My driver side low beam is not working. I tried 2 brand new bulbs,and nothing.
All the wires in the harness seem to be ok, and no blown fuses. Driver side high beam works fine.
Suggestions? It's rainy and cold don't wanna go back out there right now lol
Old Jan 7, 2009 | 01:01 PM
P_Adams's Avatar
Default Re: Headlight Out
You may have either lost the ground connection for that circuit, or the colume mounted headlamp switch has failed.
Each headlamp bulb has it's own feed from the switch, and it's own ground at the chassis.
A quick test with a test lamp will determine which
P
Old Jan 8, 2009 | 04:51 AM
awdgsx96's Avatar
Thanks for the advice.
I actually had a short right in the fender with the harness. There was a 1 inch burn in the wire. I found it when I noticed it was smoking lol
Old Jan 8, 2009 | 05:08 AM
P_Adams's Avatar
Well, That's one way of finding it.
It sounds like a Mythbusters' episode
P
reesmicm
Jun 16, 2019 03:24 PM
reesmicm
Lighting
Jun 16, 2019 03:21 PM
reesmicm
Honda CR-V & Element
Jun 15, 2019 01:13 PM
jasoncanseeoh
Lighting
Feb 9, 2010 01:54 PM
oj5joker
Jan 8, 2009 10:14 AM
