Remanufacture TCM!!!
Old Jan 7, 2009 | 02:06 AM
smkngsr's Avatar
Default Remanufacture TCM!!!
Who sells the least expensive remanufacture TCM because my accord S light keeps coming on occasionally when im drivin. So i need to replace before anything goes wrong...pls advice
Old Jan 7, 2009 | 04:26 PM
slomofo's Avatar
GDD Member
Default Re: Remanufacture TCM!!!
Did you check the codes yet or are you just guessing that's the problem?
Old Jan 7, 2009 | 07:30 PM
P_Adams's Avatar
What year is it and what is it doing other that the S light flashing?
http://www.autocomputerexchange.com/Makes/Honda/1?gclid=CMrJkoOR_pcCFQJNagodBUzFDg
Certainly cheaper than Honda......
P
Old Jan 8, 2009 | 11:02 AM
Ronin1's Avatar
TCM? Is that the same as an Engine Control Unit (ECU)?
I had to have the ECU on my '99 Accord EX replaced. Not only was the part absurdly expensive (you can buy a decent computer with monitor for less), but Honda has a certain number of parts (I do not know what other ones do this) which disable the car if they are replaced and it appears that only dealers have the codes and/or equipment to reset the car so that it will run.
Edit: Oops! OK, I got it, Transmission Control Module. You still need to check out whether it will require a reset by a dealer.
Old Jan 8, 2009 | 11:12 AM
P_Adams's Avatar
Ronin:
Confusion on this topic is perfectly understandable.
Up to (and including) the 1997 model year, Honda used seperate ECM's and TCM's for their products.
That changed with the 1998 model year where both the ECM and TCM were incorporated into a PCM (Powertrain Control Module).
And then there's the issue of the immobilizer; making it %$^# near impossible to swap in a used PCM if you don't know the donors VIN Number - nasty.
P
RobertMcC
Jul 12, 2023 11:23 AM
Jakester9500
Mar 20, 2017 06:54 AM
eilyasjaan
Feb 5, 2009 07:23 PM
em1blk2000
Jan 9, 2009 08:08 AM
