Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
ES1 to EM2?
Old Jan 6, 2009 | 08:19 PM
no1_suspek's Avatar
Icon6 ES1 to EM2?
sup Honda-Tech!,
this is actually my first post on this forum, and i wanted to know a little more about the ES1 suspension compared to the EM2... I really want a full blown setup for my suspension, but the product say's its for EM2...will they fit my ES1 since the engine bay is the same?!
Old Jan 6, 2009 | 09:28 PM
damian02civic's Avatar
Default Re: ES1 to EM2?
EM2 and ES1 are chassis codes located within your VIN number.
EM2 for Vtec/Non Vtec Coupe models.
ES1 for Non-vtec Sedan models.
ES2 for Vtec Sedan models.
As for your question will a "EM2 suspension fit an ES1" Yes.
01-03 have different size bolt holes in the strut housing.
04-05 have 16mm. 01-03 have 14mm.
scrooge's Avatar
its the same car yes.
Old Jan 6, 2009 | 09:49 PM
It Wasn't Me's Avatar
▌▌READ BEFORE POSTING▐▐ [Forum Guidelines]
2001-2005 Civic (Coupe and Sedan) FAQ's
Click the above links and view them. I would tell you to use the Search feature, because this topic has been covered before. However, the search feature is currently not working. It will be working again, soon.
In the future, please utilize these sources prior to making a new thread.
Thanks and welcome to Honda-Tech.
Old Jan 7, 2009 | 08:52 PM
theineffable's Avatar
stock sedan suspension is almost the same as the stock coupe suspension...
i believe the only difference was that the sedans got maybe stiffer spring rates at the rear because it's rear end is heavier
if one has a big stereo in a coupe, i wonder if it's better for them to use sedan lowering springs. would that prevent rear end sag?
Old Jan 7, 2009 | 10:23 PM
EvDog03's Avatar
I can tell you the stock struts for the em2 weren't great. Mine were completely blown out at 50k on my 01. Went to tokico's.
josh's ep3
320
Feb 13, 2023 11:17 PM
Inisharu D
Jun 24, 2010 08:32 PM
10thcb7
Suspension & Brakes
Mar 15, 2007 08:05 PM
