small suspension question
Old Jan 6, 2009 | 07:20 PM
96f22b2's Avatar
Default small suspension question
Could I do a .75 or like 1" drop on stock shocks? i know like a 2" drop would blow the shocks but would a .75?
Old Jan 6, 2009 | 08:54 PM
96F22B1Accord's Avatar
Default Re: small suspension question
Yes, you should be able to. Eibach claims there pro kit which gives about a 1.2" drop can be run w/stock shocks. So as long as you don't go lower than this it would work. However I don't know how shitty it would ride, I would imagine it might be a little bouncy.
Old Jan 6, 2009 | 09:21 PM
The-Kid's Avatar
You should be just fine. I have Eibach Pro-Kits with stock shocks. So far it's been great. But I would bet with some aftermarket performance shocks, it would be better.
Also Eibach lied about the lowering, I got more than 1.2" in the front and little more than 1.2" in the rear.
Old Jan 7, 2009 | 04:06 AM
P_Adams's Avatar
The important thing to remember is to retain the rubber bump stops which are located on the strut shafts. These are the limiting factor that keeps the suspension from grounding. Leave them off, and you'll loose the strut at the first pothole.
P
EP3 FTW
May 17, 2007 06:48 AM
Drian
Jul 12, 2005 09:55 PM
SirJinx7700
Aug 5, 2002 07:30 PM
rota426
Aug 1, 2002 02:34 PM
hobo79
Mar 3, 2002 09:17 AM
