are stock mounts strong enough?
Old Jan 6, 2009 | 03:20 PM
xander1100's Avatar
Default are stock mounts strong enough?
putting a b18c1 in my teggy. turbo charging it and looking to get 300-350 HP. are the stock mounts strong enough or will they break? what HP should i switch to aftermarket?
Old Jan 6, 2009 | 05:47 PM
rmcdaniels's Avatar
Default Re: are stock mounts strong enough?
Stock mounts are strong enough, they are just soft, making for some wheel hop, shifter movement, and driveline damage in extreme cases. You can fill them with Window Weld to firm them up, but your ride will become rougher and noisier, much like it will be with aftermarket mounts. Or you can drop the $ on Hasport or Innovative mounts, both of which are decent.
Old Jan 7, 2009 | 01:11 AM
xander1100's Avatar
anyone have experience with either brand? will using Window Weld in different dosages stiffen them different amounts?
Old Jan 7, 2009 | 11:09 AM
rmcdaniels's Avatar
I've used Hasport mounts in multiple cars. I have them in my race car now and they are great. I know people that use Innovative mounts and have seen several sets, they look fine as well.
For Window Weld, you just fill the mount with it, like this:
http://www.importnut.net/motormount.htm
For the $, I don't think that there will be anything to complain about with it.
Energy Suspension also makes polyurethane inserts for the stock torque mounts, I have used them and they seem to work, just not as well as the Hasport mounts.
Old Jan 8, 2009 | 02:36 PM
lmike6453's Avatar
I'm telling ya, if you go with stiffer mounts...you will hate your ride comfort as far as noise. BIG waste of time i layed on myself when I used motor mount inserts. Eliminated wheel hop, but the dash and interior vibrated like crazy.
Old Jan 9, 2009 | 12:16 AM
xander1100's Avatar
have solid mounts in my car right now (drove it across country with them) so i feel your pain...on the plus side they made it easier to stay awake lol. i dont mind a little vibration, just want my mirrors to be functional instead of showing triple lol.
Old Jan 10, 2009 | 03:00 PM
Danronian's Avatar
From my experience, the filled mounts are a bit less stiff than the inserts, but over time they generally deteriorate. I've used the inserts before and liked them other than the vibrations at idle. Other than the idle vibrations, they worked great with taking slack out of the drivetrain.
Aftermarket mounts are very stiff.
I think around 300hp you should be fine with the OEM mounts. In rare cases have I heard of OEM mounts failing. If I have heard of it, it's usually combined with the OEM ones being in bad shape.
Old Jan 10, 2009 | 06:01 PM
kulo's Avatar
get es motor mount inserts and engine damper
if u dont want to replace ur mounts
Old Jan 11, 2009 | 08:17 AM
NJIN BUILDR's Avatar
I used the window weld on just the rear (under the intake manifold) mount on my daily driver.It definitely firmed up the front to back movement,but the vibration level didn't change.
Old Jan 11, 2009 | 12:41 PM
greasemonkee's Avatar
Filling the mounts with 3M window adhesive is a notch stiffer than stock - vibration wise.
Using the 3M adhesive to hold the urethane inserts in place is the next step up.
Solid mounts are for the guy that doesn't mind wearing earplugs because his bulkhead vibrates and resonates with the cab. Heat exchangers may tend to fail prematurely with stiff mounts.
Old Jan 11, 2009 | 12:59 PM
Honda Bull's Avatar
Factory mounts will work decently at that power level, although it doesn't hurt to stiffen things up, as there is quite a bit of engine movement when making that power.
I have factory GSR mounts with Energy Suspension inserts (two torque mounts and rear engine/trans mount) and they have held up great over three years (with this year making 320-370 whp). My engine moves very little with just them in. You will have some vibrations with them at idle, but not nearly as much as Hasports or Innovative mounts. Depends on what you want.
Old Jan 11, 2009 | 01:59 PM
xander1100's Avatar
i heard that 3m window adhesive was almost as stiff as solids? heard about a few guys filling their mounts with 60a urethane, think i might go with that.
2kdrift
Aug 9, 2014 08:00 PM
highroller54
Jan 20, 2010 02:02 PM
pubestripe
Oct 3, 2005 09:29 PM
crxgator
Dec 30, 2003 08:53 PM
Big Business
Nov 29, 2002 05:09 PM
