GE GSR SLEEVED BLOCK $850 and other turbo parts
Old Jan 6, 2009 | 01:06 PM
Blueprint's Avatar
Default GE GSR SLEEVED BLOCK $850 and other turbo parts
hey everyone
i have a brand new GSR block sleeved by Golden eagle... when i moved my parents must have thrown away the caps or misplaced it.... ( EDIT : FOUND THE MAIN CAPS ) YAY
im asking $XXXX for the block sleeved all you need is your old caps and a line bore.... my lose your gain..
also i have
Prologger boost controller... fully loaded with 3 bar and solinoid $575
F2 drag suspension with 1000lbs spring custom vavle shock $800 shipped brand new
JE piston 84mm turbo dish piston no rings $300 brand new
Manely 84mm turbo dish pistons complete $375
REVHARD SS top mount manifold $800 brand new
Spearco front mount intercooler $475 32x11x3.5 brand new with sheetmetal custom endtanks
Turbonetics 45mm WG $329
Turbonetics T series 70mm turbo $995
lots of misc turbo parts
Hondata S300 brand new with ECU or without $650 socketed or $500 with out
H22 titlon clutch brand new $1100
H22 trans with quaife lsd factory brand new $1400
if your in so cal i got tons of pipping peices and flanges too..... must sell asap
Old Jan 6, 2009 | 02:55 PM
d-white's Avatar
Default Re: GE GSR SLEEVED BLOCK $850 and other turbo parts
i have a stock b20 would u take it a some money
Old Jan 6, 2009 | 03:20 PM
superrex90's Avatar
line hones are spendy and hard to do right. $850 might be a little high... just wanted to give any buyers a heads up that they might run into issues with getting it done, and done right. but everything else looks legit! bump
Old Jan 9, 2009 | 11:46 AM
Blueprint's Avatar
GE does the line bore for $200 or so.all im asking is for the price of the block... if you have blown block all you need to do is use the caps from that and get it line bored... any machine shop can do it .... you get a free GSR block basically... bump
Old Jan 12, 2009 | 04:22 PM
holset b18c's Avatar
offer you 500
Old Jan 13, 2009 | 11:09 AM
Blueprint's Avatar
bump still got everyting for sale... moving again
Old Feb 3, 2009 | 12:38 AM
damndan23's Avatar
the s300 has boost option? what ecu?does it come with disc-n-cable
Old Feb 3, 2009 | 02:03 AM
SD_Lurker's Avatar
HT White Ops
No it doesn't but not that it matter cause your broke as ****. Go ahead and low ball the **** outta him.
Old Mar 14, 2009 | 09:54 AM
Blueprint's Avatar
OMG i found the caps to my GSR block>>> GSR block with origignal caps pm me for pricing ...!!!
Old Mar 14, 2009 | 06:19 PM
chinesechecker's Avatar
im interested inyour pistons pls give me a call 626 i can get more info 626 6365485 jimmy
Old Mar 16, 2009 | 02:23 PM
dont know how to use this site much call me at 626 636 5485 jimmy i need pistons!!!!!!
Old Mar 16, 2009 | 02:58 PM
SD_Lurker's Avatar
HT White Ops
All of the sudden you find the mains. Makes someone wonder if they are mains you got from another block or the original mains. You should consider lowering the price of the block and someone can line bore it just to be on the safe side.
Old Mar 16, 2009 | 08:51 PM
500 still on the table!! need next 200 to get line bore!! can take the gamble!! send pictures also jojoaka420b@aol.com
Old Mar 16, 2009 | 09:34 PM
SD_Lurker's Avatar
HT White Ops
jesus dude your running around low balling the **** out of everyone. His block is worth more than that. The sleeves alone installed in a block is worth his asking price. line boring is an extra few anyways and its always wise to line bore if using main studs or a 5 girdle.
Old Mar 17, 2009 | 05:21 AM
HarfordCTR's Avatar
still have the S300? Im interested, PM me
Old Mar 18, 2009 | 10:23 AM
hey if i can save money why not low ball!! if some one bits all good, if not hey their chocie!!
if im going 2 pay over 700 for a block i can just let JGE do the work they charge little less than he is asking!!!
http://jgenginedynamics.com/Adobe%20...cer_1_1_07.pdf
Old Mar 19, 2009 | 12:00 AM
Blueprint's Avatar
i moved and my parents misplaced the caps i thought they were thrown away..... if u see the block that there were in u can tell that i didnt try to pull a fast one... lol i got really good references too the block is at my buddies shop Camp1320 Motorsports for anyone to see anytime during the day it will also be ship out of the shop eveyrhting is legit..
Old Mar 19, 2009 | 12:01 AM
Blueprint's Avatar
yeah man sorry your tripping bro... JG is junk garbage ..... they are shady and have many problems why dont you do a serach on honda-tech type in JG and u will see no one who wants problems uses there blocks.. they are also open deck and have problems with sleeves moving... they use LA sleeves and will BS u and say its darton
Old Mar 19, 2009 | 03:23 AM
non-VTEC's Avatar
hey the pm's are not working correctly.
anyway...what is the part number for the JE pistons? i know there are 2 diffrent 84mm low compression pistons from JE.
thanks
Old Mar 19, 2009 | 01:11 PM
i would do a seach but the new version of honda tech suck!! cant find $hit have to look at 500 other things 1st!! thanks for the info!!
Old Mar 19, 2009 | 01:29 PM
SD_Lurker's Avatar
HT White Ops
No but seriously, JGE is horrific, in every way shape and form. Javier made the comment "until I have a lawsuit I just don't see myself having a customer service problem". Would you still consider sending your block to him after hearing such a comment?
Old Jul 22, 2009 | 06:02 AM
TeggyGuy2392's Avatar
I was wodering if the bloakc and je pistons were still available?
thanks
Old Jul 22, 2009 | 12:27 PM
SD_Lurker's Avatar
HT White Ops
thanks
Seriously?
ej2_coupe
May 31, 2012 11:35 AM
Blueprint
Dec 13, 2008 08:44 AM
TEAM562racing
Jul 8, 2006 09:01 PM
TurboITR
Mar 11, 2003 03:10 PM
