oil pump leaking?
Did you use RTV silicone when you installed it? If oil is not coming from the surrounding areas of the OP, more than likely the front main seal (center of the oil pump) is damaged.
Well if you didn't use a sealent on the pump when you installed it it is leaking all around the oil pump and since you are going to have to take it out to seal it you might as well replace the front oil seal
Mr. Future
Nov 22, 2015 07:46 PM
Corksil
Jan 25, 2011 10:36 AM
