quick question about axles for ls swap in eg
Old Jan 5, 2009 | 07:48 PM
98integralsB18's Avatar
Default quick question about axles for ls swap in eg
hey just a quick question. im about to swap a odb1 ls into a 92 eg and was wondering if i needed any special axles for it, or just any b series axles.
Old Jan 5, 2009 | 08:47 PM
z6hatchboy's Avatar
Default Re: quick question about axles for ls swap in eg
94-01 teg axles im pretty sure work, idk about 99-00si ones or previous teg axles
Old Jan 6, 2009 | 05:28 PM
infinitypro12's Avatar
I would concur with the teg comment.
Old Jan 6, 2009 | 05:33 PM
nix94delsol's Avatar
nope, 99-00 si are too long
93 and below are too short
Old Jan 6, 2009 | 09:05 PM
94EG8's Avatar
Seagull Management
And where exactly did you come up with that info?
'99 - '00 Si axles are identical to '94 - '01 integra axles they are also exactly the same as '94 - '97 Del Sol Vtec axles, all of which work fine. '90 - '93 cable axles work as well if you use the corresponding cable intermediate shaft and axle seal. Basically what you run for axles depends entirely on what intermediate shaft you use, if you're using a hydro intermidiate shaft use B-series hydro axles, if you are using a cable intermediate shaft then use B-series cable axles.
Old Jan 6, 2009 | 09:37 PM
InTheLBC20's Avatar
i concur with 94EG8. BTW i used 95 Integra axles for my swap
Old Jan 6, 2009 | 09:38 PM
InTheLBC20's Avatar
i also agree with his signature too
lilsicsoul
Mar 18, 2009 04:56 AM
TNT
Apr 13, 2007 08:41 PM
Shonda
Oct 18, 2006 07:57 AM
88 rex
Jul 29, 2005 07:49 PM
twin rex's
Jun 27, 2004 07:58 AM
