quick question about axles for ls swap in eg
hey just a quick question. im about to swap a odb1 ls into a 92 eg and was wondering if i needed any special axles for it, or just any b series axles.
Seagull Management
Re: quick question about axles for ls swap in eg
And where exactly did you come up with that info?
'99 - '00 Si axles are identical to '94 - '01 integra axles they are also exactly the same as '94 - '97 Del Sol Vtec axles, all of which work fine. '90 - '93 cable axles work as well if you use the corresponding cable intermediate shaft and axle seal. Basically what you run for axles depends entirely on what intermediate shaft you use, if you're using a hydro intermidiate shaft use B-series hydro axles, if you are using a cable intermediate shaft then use B-series cable axles.
lilsicsoul
03-18-2009 04:56 AM
