to anyone whose swapped from d series to b18 LS motor...IACV wiring question
Old Jan 5, 2009 | 07:27 PM
hotcivicsi's Avatar
Default to anyone whose swapped from d series to b18 LS motor...IACV wiring question
I have a 98 civic dx that had a LS swap done to it....trying to figure out my idle problem I found out that the IACV is not even plugged in, therefore ecu isn't controlling the idle. I don't have a connector off the harness that seems to fit. Is there a mod that has to be done for this to get connected.
help me out
thanks
Old Jan 6, 2009 | 02:31 PM
hotcivicsi's Avatar
Default Re: to anyone whose swapped from d series to b18 LS motor...IACV wiring question
someone has to have a ls swap...help me out
Old Jan 6, 2009 | 02:37 PM
GYChris's Avatar
You say you can't find a plug that fits.. Are there any disconnected plugs under/behind the intake manifold? You want to look for a yellow w/ black striped and a blue w/yellow striped set of wires for the IACV if I remember correctly.
If the plug doesn't fit then simply go to the junk yard and find one that does, cut it and reconnect to the wires i mentioned above and plug it in.
Old Jan 6, 2009 | 03:08 PM
hotcivicsi's Avatar
Ya I have 2 loose plugs but both dont fit I think the person who did the swap used the civic harness. I might just pick up a ls harness and use what I need off it like u mentioned.
Old Jan 6, 2009 | 03:39 PM
cruizinmax's Avatar
Do you have a three wire plug that looks like this?
http://www.ff-squad.com/tech/wiring/wiring.96-98.jpg
Old Jan 6, 2009 | 03:54 PM
speedooo's Avatar
y7's have a 3 wire, everything else is 2 wire...
Old Jan 6, 2009 | 04:06 PM
-=ZAK=-'s Avatar
mine idles the same way as your and i have the right plugs i cant figure out what the problem is. i tried cleaning the iacv and othher stuff the only thing i can think of now is a bad tps.. or high timing
Old Jan 6, 2009 | 04:19 PM
94EG8's Avatar
Seagull Management
Automatic Y8s are also 3 wire.
Old Jan 6, 2009 | 05:19 PM
hotcivicsi's Avatar
yaaaa boiii thats exactly what i needed..... thanks a lot man
you guys know of any other connectors that should have been modified or changed?
thanks
Old Jan 6, 2009 | 05:49 PM
speedooo's Avatar
wonderful, his car is a dx that had a y7
Old Jan 6, 2009 | 06:36 PM
hotcivicsi's Avatar
actually do you guys know if I have to change the pins for a non vtec engine?
Old Jan 6, 2009 | 06:47 PM
speedooo's Avatar
it has nothing to do with vtec. the y7s/auto y8s had a 3 wire iacv, everything else is 2 wire. theres a write up on here about it somewhere
Old Jan 6, 2009 | 06:54 PM
hotcivicsi's Avatar
Well right before step 1 it states: "if your a 96-98 non vtec or a/t civic owner...."
thats why im asking if the pin out has to be changed if I have a non vtec ls motor.
Old Jan 6, 2009 | 06:58 PM
speedooo's Avatar
they mean if it comes stock without vtec, aka cx/dx/lx
Old Jan 6, 2009 | 07:08 PM
hotcivicsi's Avatar
ya my civic is a dx
SleepyHatchZ6
Mar 31, 2010 11:43 AM
ivan93egreppin210
Apr 10, 2008 04:03 AM
SpoolinEK9
Jan 9, 2005 11:33 AM
Boofster
Jan 27, 2004 07:49 PM
sydag5
Jul 23, 2002 04:05 AM
