O2 Sensor Help 4 wire
Ive got an ls vtec in a crx that is converted to obd1 except for the o2 sensor. I have searched and have found two ways to do it. One is splicing into other wires and one is going straight to the ecu. Which is the best way and can someone explain to me how to do it because i am really confused. Thanks
What ecu are you using?
You need to get a connector and pigtails for it. You can wire it to the ecu.
four wires= 12v,one heater,one signal,and one ground.
O2 Sensor Input - WHT to D14 (needs to be a shielded wire)
Heater Control - BLK to A6
Sensor Ground - GRN to D22
Sensor Voltage - BLK to A25 or B1 (both are 12-volt sources, so either works fine.)
Dancing is Forbidden
Nov 18, 2003 08:51 PM
