What to Do Now? Help
Old Jan 5, 2009 | 04:36 PM
civlxbro's Avatar
Default What to Do Now? Help
Sup guys, for the record I have a 99civic lx sedan!
The car currently has just about 130k on the clock. I was wondering if there was a maintenence thread or a direction someone could point me in. Im looking to help keep this car running untill its last breath. If someone could help me out Id greatly appreciate it!
Old Jan 5, 2009 | 04:53 PM
NJIN BUILDR's Avatar
Default Re: What to Do Now? Help
Change the fluids according to the Honda manual.Repair things as they wear out.Change the fluids according to the Honda manual.Repair things as the wear out. Etc...
Old Jan 5, 2009 | 05:46 PM
srmofo's Avatar
yup follow the maintance guide in the owners manual and you'll be good for a while...btw if your timing belt/water pump hasnt been done, your way over due....get to that asap
Old Jan 8, 2009 | 02:42 PM
lmike6453's Avatar
I would change the O2 sensor, get magnetic drain plugs, check motor mounts, use full synthetic Mobil1 oil with Mobil1 oil filter, iridium spark plugs, tune up with new spark plug wires, dizzy cap n rotor, test the coil inside the dizzy(resistance should be .6-.8), check fuses, test alternator n battery, timing belt and water pump, fluids, plus a lot more.
WaterHoes
Jun 24, 2013 09:45 AM
mrinno
Sep 19, 2007 04:55 PM
boostincoupe
Jul 1, 2003 12:38 PM
Toda Built
Mar 23, 2003 11:31 PM
imported204
Apr 27, 2002 11:23 AM
