My 99 Si Slow DD Build
Old Jan 5, 2009 | 09:42 AM
jksmith's Avatar
Default My 99 Si Slow DD Build
This is my first full build, and will be very slow due to lack of funds, just bought a house....
car is a 99 Honda Civic Si , w/ roughly 150,000 miles on it,
Here is the car when i first got it
Mods:
stock b16a bottom end
Strup header
Shunk2 intake mainfold
Shunk2 Throttle body, 68mm
Buddy Club spec 4. cam shafts
Buddy Club cam gears
Supertech springs
Shunk2 TI retainers
AC fuel rail.
AEM Fuel pressure regulator
Walbro 255
apexi exhaust,
magnaflow high flow cat
short shifter
Excedy stage 2 clutch and ACT flywheel (slipping very bad)
Chipped P28 tune on chrome
Skunk 2 Front Camber Kit
Tokico ADJ shocks w/ Skunk 2 coilovers
Type R Front Lip
Stock Interior - 8 out of 10 - except for the carpet, some how car got flooded and carpet was soaked, nothing else got wet
More bad stuff: the tune on the car was terrible car wouldnt stay in vtec and cut out xtremely bad in high rpms, car is very cold natured and wont stay started until it warms up, think thats just the cams tho...
and the heater core needs replaced, no biggy just a pain in the ***
so i knew it need a new clutch right away and got the car home and up on the lift, the axle boots were off and grease was everywhere, so i decided to just rip the motor out of the car completely
so i had this laying around
LS Block - 81.5MM
LS Polished Balanced Crank
JE 12:1 Pistons w/ new rings
Eagle Rods w/ ARP Rod Bolts
Cometic Headgasket
Arp Rod Bolts
Golden Eagle LS/V Kit
BNIB GSR Oil and Water Pump
so since its my DD and have to use it to get back and forth to work and to get the motor in right away,
i decided to keep my power steering.
here are my near future plans
1. little bigger injectors
2. new header
3. get a wideband
4. get tuned
sometime this spring when it warms up here in Indy...
Wire Tuck & Shave
SS Brake Lines & Tuck
SS Fuel Lines
Finally get that ugly valve cover Powder Coated
get the engine scrubbed down and repainted
this is stuff i also want to get done in the mean while...
Rear Camber Kit
Rear LCA's
Rear Tie Bar
Direct Port No2 System
Old Jan 5, 2009 | 11:30 AM
ImportHatch's Avatar
Default Re: My 99 Si Slow DD Build
Nice build man.
Old Jan 7, 2009 | 10:10 AM
jksmith's Avatar
got the car up and running, let the car idle for a while, changed to oil, started it back up back it out of the garage took it for a drive about 5miles done the road timing belt started jumping around ... so i had to have it towed back to the house
think my tensioner came loose, will check it out tonight was to pissed to finish it up,
hope i didnt mess my head up!!
Old Jan 8, 2009 | 09:37 AM
SonicRacing's Avatar
bumb.. whats the name of the current rims on the car?
Old Jan 8, 2009 | 09:52 AM
Chris.'s Avatar
Honda-Tech Order of Merit
rota track r
Old Jan 9, 2009 | 10:44 AM
jksmith's Avatar
yep rota track r's
Old Jan 10, 2009 | 05:17 PM
joeycrakk1109's Avatar
loookin pretty good.....car wud look better wit oem si lip ;]
Old Jan 11, 2009 | 12:39 PM
jksmith's Avatar
lol, i just should my oem si lip for $130
Old Jan 12, 2009 | 12:21 AM
black_EM1's Avatar
Community Builder
Community Influencer
Get an OEM lip. Soon.
Before that, get your car tuned. 12:1C/R untuned is asking for trouble.
Old Jan 12, 2009 | 04:12 AM
jksmith's Avatar
yea, waiting on new injectors, fuel pump, new header, and a few other things to come in before i get it tuned... its still sitting in the garage...
Old Jan 12, 2009 | 08:43 AM
jksmith's Avatar
finally found my usb cord for the camera, here is a few snaps while it was in the garage....
Old Jan 14, 2009 | 11:21 AM
Mr. Em1's Avatar
nice lookin build man. did you get it tuned yet? that think shud put down some good numbers
Old Jan 15, 2009 | 07:34 AM
jksmith's Avatar
Haven't got it tuned yet car had just be sittin go about 10 miles on it waitin on a few parts to come in .... Walbro, injectors, and new header ..... My header is crushed prolly 1/2" runners on the bottom side
Old Jan 15, 2009 | 08:59 AM
Ls_dx's Avatar
Man shes purdy... I <3 EM1's!!
Old Jan 16, 2009 | 02:39 AM
No VDUBS here in206's Avatar
very nice
Old Jan 16, 2009 | 03:36 AM
jksmith's Avatar
thanks guys, will try to get some pics, but the car hasnt moved much still just sitting there, its COLLLLLLLLD here in indy
Old Feb 8, 2009 | 12:32 PM
jksmith's Avatar
little update, no pictures tho, car is still sitting havent been able to drive it, after i got the car running drove it for about 5 miles the tensioner backed out on me
still havent diagnosed why, but just decided to order a new one should be here this week and then i have a dyno session coming up early march
got my injectors and walbro in
still havent ordered a header yet tho, cant decide which one to get, plus i just bought a house so budget is realllll low
Old Feb 8, 2009 | 04:12 PM
pingar's Avatar
nice build..looking good.
Old Feb 8, 2009 | 06:59 PM
black_EM1's Avatar
Community Builder
For a header, look into a Profab, VtecKiDD, or something of the like. They're decently priced.
What injectors did you get, 310cc's?
Old Feb 9, 2009 | 04:52 AM
jksmith's Avatar
yea been talking to vtecKiDD
yep RC 310's paid a big $60 for the set basically brand new
jksmith
Dec 10, 2008 10:43 AM
kole317
Dec 5, 2008 09:55 AM
SIK-99
Jul 24, 2008 10:22 AM
101998
Aug 17, 2003 11:58 PM
